Break down
Started by BazaJT, 15 February 2014, 16:32:39
Toledodude1973
Just read manual, does state 50mph max and 60miles max , if i was being towed in any car thats plenty fast enough/far enough for me so didn't need to worry :) :)
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
If you are EVER offered a tow of more then 5 miles .... do your best to turn it down..... !!
What folks forget, is that whilst being towed on either a rope (bloody dangerous) or even on a bar (much safer) with the engine stopped the power steering does not work .... after about 5 miles the arms are aching and the blood pressure is rising .....
BTW .. before anyone comments .. the reason a rope tow of an Omega is bloody dangerous is the brakes will, effectively, cease to work after the 3rd press... at least on a bar tow there is a chance of stopping !!!
Quote from: Entwood on 15 February 2014, 21:24:45
BTW .. before anyone comments .. the reason a rope tow of an Omega is bloody dangerous is the brakes will, effectively, cease to work after the 3rd press... at least on a bar tow there is a chance of stopping the bar folding up!!!
Fixed. :y
Agreed regarding the effort involved, though.
As you suggest ... you're very quickly reminded that there's no assistance when being towed. I forget now whether we used a bar or a rope when I ripped the sump plug from my car & needed to be towed home by my Dad. I know it was bloody hard work stopping it.  :o :o :o
Quote from: Kevin Wood on 15 February 2014, 21:35:03.... at least on a bar tow there is a chance of stopping the bar folding up!!!
Fixed. :y
[/quote]
Done that too ..... a cheap sprung thing from Machine Mart.
I always wish I'd made one  :(
BazaJT
So,up this morning ready to fight the good fight and fit a crank sensor.Now where's my sockets?Sugar they're in the boot of the Jaguar which is being kept off road 2 miles away!Set off for the walk and part way there it began to rain,by the time I got back home I was wet through and just as I got in the door it stopped raining!!!Let things be for a while to make sure rain wasn't going to start again then went to make a start.Jack up car,place axle stand under it and also leave trolley jack in place as a "belt and braces"approach.Crawl under car to find my sockets only go as small as a ten and I need an eight!Double sugar!!So leave car up in air put tools in boot and set off on another mile walk to Halfords,purchase said socket[£3.49!]and return to the fray.Engine end out time to be under bonnet for electrical connector,where the hell is it?It's nowhere near the bracket above the coil pack,finally found it under other pipework/electrical wiring back up against the bulkhead.I'm guessing the failed sensor was the original as it was routed up behind exhaust etc.Right so that's fitted with the wiring routed out to the inner wing and up over cable tray,scuttle and wipers back on and car dropped back onto floor.Time then to go for an engine start and hope that a]It was indeed a crank sensor problem that caused the breakdown and b]that I've done everything right!Turn key engine spins once,engine spins twice,engine spins for a thir no she's up and running!!!Nice even beat,steady tick over drives like a good 'un.What a relief!!Had I not been a member on here and read all these posts about such things I'd have had to pay someone to diagnose/fix problem and might well have got ripped off in the process.Once again the power of OOF and the spirit of it's members in sharing their knowledge shines through!!
Shackeng
Well done Baz, you certainly suffered enough getting that fixed. I keep a spare crank sensor in the boot of the 3.2, and a set of tools on long journeys. :y :y :y
PS I've lived in Epworth & Haxey
BazaJT
Yes I think my next purchase for the Mig will be another crank sensor to replace the "spare" I've just fitted.Ah,Haxey not the place for a gentle stroll on the streets when the "Haxey Hood"is on the go!!!
Shackeng
Quote from: BazaJT on 17 February 2014, 19:52:38
I played in that before Elf & Safety got their hands on it! Not for wimps, only idiots. I was both! :y
