Author Topic: Non Starting Issue  (Read 1162 times)
cliff
  • Basildon, Essex
    • omega 2.6 cdx auto 2003
Non Starting Issue
« on: 16 February 2014, 11:03:08 »
Hi, I have a 2003 2.6 auto CDX Omega. I had a flat battery, took it off the car and re-charged it over night. Stuck it back on. The engines spins nice but won't fire. Had a auto electrician look at it but can't find the fault. Have you got any ideas? Thanks
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
Re: Non Starting Issue
« Reply #1 on: 16 February 2014, 11:29:35 »
Is the engine management light on ?
Potentially crank sensor is u/s.
Try the pedal trick to reveal any codes and post them on here, someone will help.
Paddy Flannery
    • 2003 2.6 V6
cliff
  • Basildon, Essex
Re: Non Starting Issue (done a pedal test)
« Reply #3 on: 17 February 2014, 20:59:45 »
Hi,
I've just done the pedal test and it has come up as:
10 flashes
3 flashes
3 flashes
5 flashes
Can someone please advise what this might mean.
Thanks
Paddy Flannery
    • 2003 2.6 V6
« Reply #4 on: 17 February 2014, 21:23:58 »
Crank sensor is u/s. Only replace with a genuine Vauxhall one as pattern ones have been known to fail early.
cliff
  • Basildon, Essex
« Reply #5 on: 18 February 2014, 17:35:01 »
Thanks Paddy
