Author Topic: best place for cable feed to interior  (Read 2106 times)
darrenfos
  • eastleigh
    • omega elite manual
« on: 17 February 2014, 19:43:37 »
Hi all, where is the best place to feed cables to the interior from engine bay as i am fitting cobra parking sensor's to front of the car, I have had a little look in foot well area under dash, so i need to find a place to bring cables in so any advice would be good. Thanks
omega is like marmite you know the rest
Re: best place for cable feed to interior
« Reply #1 on: 17 February 2014, 19:55:39 »
Usually one or two grommets either side of bulkhead to feed through
« Reply #2 on: 17 February 2014, 19:58:25 »
In the pollen filter housing is a large OE bunch of wires going through the bulkhead. Just above it is a small blanking grommet, this is where I passed a cable through for my tow bar gubbins. :y
I_want_an_Omega
« Reply #3 on: 17 February 2014, 20:28:35 »
On estates it's where the pipe for the rear washer goes ..............
« Reply #4 on: 17 February 2014, 20:34:32 »
That makes sense. It was the only place I could find on the whole of the bulkhead.
darrenfos
  • eastleigh
« Reply #5 on: 17 February 2014, 20:41:49 »
i had to go have a look, anyway i found a pop out grommet bit bigger than a 2p under drivers side scuttle which will be perfect. thinking of connecting it straight to cig lighter + as its a switch on/off system.
« Reply #6 on: 18 February 2014, 01:09:42 »
That's as good a route as any :y, but why not power it from the fusebox about 6inches from said grommet on the bulkhead, can fuse it there too, and fit a suitable switch next to the headlight switch :-\ if your car has/had Traffic Master fitted, you don't even need a new switch...
darrenfos
  • eastleigh
« Reply #7 on: 18 February 2014, 12:15:23 »
Shall i just use a fuse jumper and to which fuse. Cheers
« Reply #8 on: 18 February 2014, 14:08:40 »
Take your pick, but ideally one that's ignition switched... black wire iirc :y
darrenfos
  • eastleigh
« Reply #9 on: 18 February 2014, 14:10:26 »
What do you mean by black wire. Thanks
darrenfos
  • eastleigh
« Reply #10 on: 18 February 2014, 15:02:35 »
Is the black wire on the cig lighter the live one if so i will use that cheers
« Reply #11 on: 18 February 2014, 16:43:40 »
+12V on the Omega comes in two flavours...
1. Permanent live = Red
2. Switched live = Black
If you want a switched live, then you need a black wire ::)
I would add another fuse as I guess your parking sensors are a lower ampage than the cigarette lighter socket.
Haynes manual is your friend when it comes to wiring diagrams... will soon tell you if the wire you're thinking of does what you need it to :y
