Author Topic: Poxy Light again  (Read 4399 times)
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
Poxy Light again
« on: 17 February 2014, 20:58:57 »
Hi guys,
After cursing and moving various wires and the Alternator I managed to get to my defective knock sensor and refitted as instructed by various members, which was great
after doing some other things on my to do list today I took it to the mot station for the dreaded yearly tick list  :-X :-X
Good thing is it passed few advisorys steering idler and slight oil leak and vaious other crap
GOOD NEWS SHE PASSED!!!!
BUT>>>>>>>>>>>
I have had engine management Spanner come back on on the drive home so I turned around and took it back to my workshop to plug on diagnostics
its saying Knock Sensor Bank 1 Circuit 1 PLEEEEEAAAAASSSSSSSSSEEEEEEEEE tell me its not the f#cking sensor I spent ages trying to get to, does this mean Steve @ Omega Spares sold me a dodgy??
Sam
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
Re: Poxy Light again
« Reply #1 on: 18 February 2014, 01:06:28 »
Reading your post a couple of things are apparent...
1. You refitted the suspect sensor rather than replacing it with a known working one.
2. If there is a problem with the new one, get in touch with Steve and talk to him before publicly bad mouthing him  :-X
That said, have you considered that either the wiring has been routed wrongly, or horror of horrors, that there's another problem causing the knock sensor to activate, thus putting the light on :o
I know that's a bit left field and all...
« Last Edit: 18 February 2014, 01:17:33 by Taxi Al »
« Reply #2 on: 18 February 2014, 20:33:14 »
Any other codes, as the knock sensor one would have been stored from the previous knock sensor. Also, the diags machine should have told you if this code was still valid, or historic.
skyblue
  • Bracknell
« Reply #3 on: 18 February 2014, 20:44:45 »
Sam, I cant help you with your car problem, but I can assure you that Steve WOULDN'T rip you off. Give the chap a call and I can bet my bottom dollar that he will want to help you out of the pickle you find yourself in.
Sam Burton
    • Many
« Reply #4 on: 18 February 2014, 22:11:24 »
1. You refitted the suspect sensor rather than replacing it with a known working one. I replaced
The engine sounds fine no knocks or bangs slight blow from the near side exhaust manifold gasket but nothing engine related I'm not bad mouthing anyone but I'm annoyed that I've got to do the same job twice because it doesn't work
I've cleared the code several times after fitting the replacement sensor to which the light comes back the car seems hesitant with the light off and as soon as the light is on its almost like its accepting the fault and restoring some level of power
Sam Burton
    • Many
« Reply #5 on: 18 February 2014, 22:12:36 »
Good to know but I've tried contacting him several times over the last couple of days to no avail but I'll wait a few more days as I understand people are busy  :y
« Reply #6 on: 18 February 2014, 22:14:34 »
Thats always the risk with 2nd hand sensors. That breaker is a breaker, probably unable to test that sort of part.
However, as that sensor is reliable, the chances of 2 failing  :-\.  I'd be initially checking the wiring, if that checks OK, anything that could be making the sensor pick up a (false) knock.
« Reply #7 on: 18 February 2014, 22:15:43 »
I'd also add, although I've not used that breaker myself, I've had nothing but good reports.
Sam Burton
    • Many
« Reply #8 on: 18 February 2014, 22:17:58 »
Good to know  :y does the knock sensor have to be bolted in to its housing or can it just be plugged in to remove the light
« Reply #9 on: 19 February 2014, 12:16:57 »
It needs to detect a knock.
Is the alternator fitted correctly, any sign of noisey bearings on the alternator?
I assume the knock sensor wire is routed ok and not trapped and damaged by anything?
Sam Burton
    • Many
« Reply #10 on: 20 February 2014, 18:13:50 »
So you can't just earth it out?
Sam
« Reply #11 on: 20 February 2014, 18:46:20 »
Sam
No
Sam Burton
    • Many
« Reply #12 on: 20 February 2014, 19:08:56 »
How tight has it got to be in its hole tight or nipped up
« Reply #13 on: 20 February 2014, 19:47:28 »
It's in Haynes... 4A.2. I assume you have one but are unable to turn the pages.[/colour]
Also it would be fair to say that if you've over tightened it, then that's your doing, and not a faulty part :-X
« Last Edit: 20 February 2014, 19:49:08 by Taxi Al »
Sam Burton
    • Many
« Reply #14 on: 20 February 2014, 19:57:01 »
Wool hold back on the insults please! A tad uncalled for being new to the petrol lumps how the hell am I suppose to know!
Regarding your implication of me not be able to turn the pages I may be unwise when it comes to v6 lumps but I have nothing but respect for other people knowledge when it comes to questions.
And no for your smart arse comment I don't own a Haynes manual for it! only the DTi one I had
Good to know I'm well respected on here sorry I asked!
« Last Edit: 20 February 2014, 19:59:27 by Sam Burton »
