Author Topic: Spark plug broken  (Read 1507 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Spark plug broken
« on: 18 February 2014, 16:41:45 »
Took out spark plugs today and one of the ceramic bits broke about 3mm and I believe a bit might have gone in engine :(
Tried to get it out but couldn't. do I leave it and hope for the best or is it off with his head?
Cheers Ian
Re: Spark plug broken
« Reply #1 on: 18 February 2014, 16:52:47 »
Its ceramic so will probably be fine, worst case the piston will crush it leaving a slight witness mark and then blast it out the exhaust valve, best case it will just exit out the exhaust valve.
Do try a hoover down (or around the top of) the spark plug hole though (turn the crank so the inlet or exhaust valve is open)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #2 on: 18 February 2014, 17:23:38 »
How about a hoover pipe reduced down to a plastic tube with tape, then through the plug hole. :-\
« Reply #3 on: 18 February 2014, 18:01:29 »
I had this before many moons ago in the 2.2, electrode broke off. New plugs and all is fine, that was around 70k ago  :y
plym ian
  • Plymouth, Devon
« Reply #4 on: 18 February 2014, 18:25:06 »
Managed to get it out but now eml is on and was a bit rough on start up don't no what I have done but must be to do with coil pack I'd suspect as it was the only thing I touched.
Also cam gasket needs doing as all 4 wells full of oil :)
Shackeng
  • Ramsbury
« Reply #5 on: 19 February 2014, 19:01:05 »
Would be helpful to know what worked :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #6 on: 19 February 2014, 19:05:43 »
So will you be the first to try the £10 gasket
http://www.allgermanparts.co.uk/
plym ian
  • Plymouth, Devon
« Reply #7 on: 19 February 2014, 21:16:42 »
Remembered I had one of them long flexi grab things. Lucky I could see it on the top of the piston.
No won't be giving the £10 gasket a go as I've got a spare in a cupboard somewhere
