Author Topic: 2.5 V6 cam gasket replacement  (Read 3910 times)
Busker75
  • Derbyshire
    • Omega 2.5 v6 CDX
« on: 20 February 2014, 13:08:55 »
Howdy all....Ill begin by saying my v6 is smoking like a trooper as oil is dripping out the cams badly now. I have took of the plentum before so I know that I am half way there but I need to take the inlet manifold off so any tips help or advice will be gratefully appreciated...some body suggested taking one of the fuses out before de pressurising the fuel line ???
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: 2.5 V6 cam gasket replacement
« Reply #1 on: 20 February 2014, 13:27:07 »
Never bothered de pressurising tbh, I just undo the 17 and 19 mm nuts on the fuel rail.
Remove the vacuum pipe off the fuel regulator and get on with it  :y
You will get some petrol spillage so a few rags at the ready and away you go  :y
JUST MAKE SURE THE ENGINE IS COOL FIRST  ;)
Busker75
  • Derbyshire
    • Omega 2.5 v6 CDX
« Reply #2 on: 20 February 2014, 14:49:02 »
cheers tiger .....did you bother with torque settings ?? if so what were they mate?
« Reply #3 on: 20 February 2014, 15:15:13 »
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #4 on: 20 February 2014, 16:17:55 »
Detailed how to with pics of removing inlets in my ECT replacement guide...
http://www.omegaowners.com/forum/index.php?topic=113765.0
RIP Paul Lovejoy
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 20 February 2014, 16:20:57 »
Cam cover bolts are 8Nm  :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #6 on: 20 February 2014, 17:45:58 »
I was about to observe that no-one sells torque wrenches going as low as 8Nm, but I see Machine Mart sell a 1/4" electronic torque wrench going from 3-30Nm. It costs £78, bit pricey for me I trust all you experts use them all the time.
« Reply #7 on: 20 February 2014, 17:51:34 »
I have 2 torque wrenches that do 8Nm ..   a Sealey 2-24Nm model no STW1012 and a Teng 5-25Nm model no 3892AG-E1
Google implies both are still available
http://www.ebay.co.uk/bhp/sealey-stw1012
http://www.ebay.co.uk/itm/Teng-3892AG-E1-Torque-Wrench-5-25nm-3-8-Drive-Angular-/140409612587
HTH
terry paget
    • 3 Astras 2 Vectra
« Reply #8 on: 20 February 2014, 18:58:27 »
Many thanks. I shall order one.
Busker75
  • Derbyshire
    • Omega 2.5 v6 CDX
« Reply #9 on: 21 February 2014, 10:05:02 »
many thanks chaps ive booked myself next sunday to do the job......check this out what I found on you tube   :)
http://youtu.be/PczuE0tH7Xw
Webby the Bear
  • Northampton
« Reply #10 on: 21 February 2014, 13:25:03 »
I watched that video, Busker. I think the lad does pretty good. it's cool to see how different people do different things. E.g. I would leave all the front plastic trim in place. I would also remove the inlets in their entirety as opposed to unplugging the fuel rail. But, he did it. Good job  :y
RIP Paul Lovejoy
« Reply #11 on: 21 February 2014, 13:51:51 »
Its so so, a few key bits to avoid doing and a key one is unpluging all the individual injectors (seen it to many times where the connectors are not re-fitted properly).
I propose that everybody does this job at least five times, you get pretty slick then  ;D ;D
« Reply #12 on: 21 February 2014, 14:11:35 »
Once is enough  ::)
bored bigyin54
  • south wales
    • black beast
« Reply #13 on: 21 February 2014, 14:22:07 »
Once is enough  ::)
never is enough  ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #14 on: 21 February 2014, 15:19:31 »
Once is enough  ::)
never is enough  ;D
use pattern parts  ???
Hoof'land storeman.
