Author Topic: Aux belt tensioner assy for 2.5td  (Read 1988 times)
Magwheels
    • 2.2 dti Elite saloon
« on: 22 February 2014, 14:15:46 »
Would anybody have or know where to get a aux belt (fan belt) tensioner assembly second hand in or around the South London/ top end of Kent area for a 2.5td?
Mine had seized solid and in trying to get the thing to move I broke it!!
I can travel as still got the motorbike but prefer not to far.
Cheers
Re: Aux belt tensioner assy for 2.5td
« Reply #1 on: 23 February 2014, 11:01:30 »
If no joy here, you could try Landrover or BMW specialists, or scrapyards.  The cast 90 degree arm is quite brittle. Never force it.
Magwheels
« Reply #2 on: 23 February 2014, 14:06:18 »
Yep, know that now, wow very fragile! Mind you I had to try and get it moving as it was pretty much solid and not putting any tension on the belt unless I forced it, then it would back of after a while. The tensioner spring didn't have enough force to overcome the friction of the mount.
I have found a P38 breakers with one but that requires postage but I hoped there may be one a bit more local that I could get one from quicker.
Cheers for the reply though.
