College assignment help needed re transmission torque
Started by Webby the Bear, 24 February 2014, 21:47:04
Webby the Bear
Hi guys,
Hopefully this is straight forward:
In the following pic....
...we can see that reverse gear has the same everything almost as first gear (which produces the most torque)..... so why is the ratio like -2:1 thus giving the impression the torque is not existant in reverse?
help lol  :-[
Cheers :)
RIP Paul Lovejoy
At a guess, its because the torque is in the "opposite" direction .. positive torque gives a forwards motion, negative torque gives a rearwards (reverse) motion ??
Gearbox output torque in reverse is the reverse of the input torque hence it creates a negative torque with respect to the input
Webby the Bear
Fair enough, Nige. I just assumed the torque would be calculated irrespective of direction. :)
RIP Paul Lovejoy
Webby the Bear
Quote from: Marks DTM Calib on 24 February 2014, 21:56:41
Thanks Mark. is there then a torque measurement not in comparison of the input shaft? (if that makes sense)
RIP Paul Lovejoy
