Looking for a real Lotus Carlton
Started by RobseyMV6, 25 February 2014, 18:59:31
RobseyMV6
Anyone know of one or someone with one that needs work or restoring?
Know are a few up for sale but i want one i can fix up...
Look forward to hearing  :y
GastronomicKleptomaniac
Bagsy coming down and giving you a hand if/when you do find one :y
jonny2112
Might be worth popping over to ABS ?
Quote from: jonny2112 on 25 February 2014, 19:20:15
Seconded. Have a look on the ABS forum if you're a member. If not, it would be well worth joining IMHO. :y
RobseyMV6
Quote from: Kevin Wood on 25 February 2014, 19:27:39
Yes good point  :y
Hope as friendly as here or i'll be kicked back to tell you off Kevin  ;D ;D
Just messing  :y
It's a bit(!) quiet compared to here, but if there's a vehicle kicking around anywhere, they'll know about it.
RobseyMV6
Quote from: Kevin Wood on 25 February 2014, 19:31:48
Need to finish the limited set off now and lotus is the missing key....  :y
Quote from: RobseyMV6 on 25 February 2014, 19:46:52
Just don't turn it into a taxi. ;)
RobseyMV6
RobseyMV6
Quote from: Kevin Wood on 25 February 2014, 19:51:08
Safe to save it will be a show vehicle  :)
Dare you... :D
RobseyMV6
Quote from: Taxi Al on 25 February 2014, 20:20:35
Dare you... :D
Don't do that!!!!  ;D
cd 2.2
That Sir would be the most awesome Taxi ever imagined! This now has to be done (as long as you can get it plated ofc) and I double dare you  :D
plym ian
Quote from: cd 2.2 on 25 February 2014, 21:14:34
To be fair, Rob does run a VXR8 as a cab, so anything is possible ::)
That said, I doubt an LC is Euro2 compliant, let alone Euro 4 :-\
