Pages: [1] 2 3  All   Go Down
Author Topic: Battery Charging ?  (Read 6784 times)
Battery Charging ?
« on: 28 February 2014, 11:28:58 »
Ive had my battery on charge for 24 hrs on an Optimate charger , the charger says its still charging but has not gone into the green fully charged . Surely it should be charged by now  :-\
Re: Battery Charging ?
« Reply #1 on: 28 February 2014, 11:32:46 »
Depends on the charge rate of the charger, the capacity of the battery and discharge state of the battery before charging started
« Reply #2 on: 28 February 2014, 11:34:44 »
The battery was almost flat , barely enough to open the central locking  :( Charger is one ive used for years on motorcycles ive had , not sure on the charge rate .
« Reply #3 on: 28 February 2014, 11:39:48 »
Maximum charge rate 14.3V
vauxlooney
  • southport
    • omega 2.5
« Reply #4 on: 28 February 2014, 11:47:00 »
how long was it left flat for? they dont take to well to being flat :(
« Reply #5 on: 28 February 2014, 11:51:19 »
Probably a few days near flat , ive heard sometimes they dont recover but charger is saying its charging . Normally it goes to red if its knackered but havent seen it go to desulfate mode .
« Reply #6 on: 28 February 2014, 11:56:04 »
Thats the voltage, does it say the current?
Motordeath batteries are MUCH lower capacity so will charge a lot faster
« Reply #7 on: 28 February 2014, 12:03:12 »
0.6A  :-\
AndyRoid
  • Hants
« Reply #8 on: 28 February 2014, 12:05:18 »
A 70Ah battery will take 116 hours to charge from flat at a rate of 0.6A
The accepted charge rate for most batteries is 10% of their rated capacity, so a 70Ah battery would ideally be charged at a rate of 7Ah for 10 hours.
« Last Edit: 28 February 2014, 12:06:49 by AndyRoid »
martin42
« Reply #9 on: 28 February 2014, 12:06:14 »
I have some jump leads here  ;D
« Reply #10 on: 28 February 2014, 12:08:20 »
 Lucky i dont need them but my leccy meter will be in warp mode  :'(
Battery is fairly new though and Genuine VX one  :o
« Last Edit: 28 February 2014, 12:10:35 by Emd »
martin42
« Reply #11 on: 28 February 2014, 12:13:26 »
Pattern battery would have charged up quicker  ;D
« Reply #12 on: 28 February 2014, 12:17:28 »
 :-X
Its strange , i had a dream last night of picking up a battery and it disolved in my hands  :o
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #13 on: 28 February 2014, 12:19:03 »
take it back if still under warranty.remember to take receipt.
Hoof'land storeman.
« Reply #14 on: 28 February 2014, 12:21:57 »
Charge it up first, it will take 3-4 days (as charging is not nearly 100% efficient).
If you take it back the dealer will test it....if it shows flat you could face a wasted journey!  :y
Pages: [1] 2 3  All   Go Up
