Fuel tank ventilation valve location anyone.
Started by Raymienets, 28 February 2014, 14:39:52
Raymienets
Fuel tank ventilation valve still cannot clear 0443 fault code as I cannot find the valve anyone help. it's on my 2.2 is it under the underneath the trunking on the left hand side. Only lifted it a little but could not see anything.
Quote from: Raymienets on 28 February 2014, 14:39:52
Remove the front right hand wheel arch liner and you'll see the vapour catch tank :y follow the plumbing from there into the engine bay, it's a 10mm pipe iirc, which goes to an electrically controlled valve and then to the inlet manifold/breathers. This valve is what you're looking for :y
Have you the new one yet? Would give you an idea of what you're looking for :-\
Raymienets
Quote from: Taxi Al on 28 February 2014, 19:36:16
Cheers no got one hey to compare.
