Pages: [1] 2 3  All   Go Down
Author Topic: Rough running, fuel trims all over the place  (Read 5579 times)
« on: 02 March 2014, 21:24:47 »
Little Bro's car. We've been chasing a fault with this since he got it. Basically, it usually idles rough as hell, and at higher RPM, feels like its holding back.
LTFTs are at -12.% at idle (as low as they will go on this car), occasionally flagging a "Too rich" code.
When cruising, LTFTs raise to about -4%
Lamdas replaced, as old ones were looking a tad lazy. MAF replaced with a 2nd hand part, exactly the same readings as the original (within spec, but at the lower end of said acceptable values). Throttle Position Sensor reads slightly lower than what the internet implies at idle. New plugs as a matter of course (and other service items)
Oddly enough, he has never been able to change the fuel filter - he has tried several times with various filters from ECP and dealer, it never starts, until he puts original back in.
I've told him to go measure battery and charging voltages, but otherwise running out of ideas...
chrisgixer
Re: Rough running, fuel trims all over the place
« Reply #1 on: 02 March 2014, 21:35:15 »
Er, have I missed what car?
« Reply #2 on: 02 March 2014, 21:41:06 »
Hyundai, but not sure that makes a difference ;D
chrisgixer
« Reply #3 on: 02 March 2014, 21:43:00 »
Ok, have it your way. ;) ;D
« Reply #4 on: 02 March 2014, 21:47:47 »
Me no understumble  :-\
martin42
« Reply #5 on: 02 March 2014, 22:06:31 »
No comment..........
Strange as no other filter will work apart the original 1 fitted .
« Reply #6 on: 02 March 2014, 22:11:14 »
Yeah, we're wondering if some bodge was put on it to make it run well enough to sell.
Other thoughts, FPR faulty, not sure how to check without buying a tester, and finding a way to test it (there is a unique Hyundai adapter on this car.
  • Auckland
    • Mazda MPV
« Reply #7 on: 02 March 2014, 22:19:31 »
So.
blocked fuel filter + faulty (or bodged) FPR = slightly high fuel pressure at idle & low pressure at full throttle.
martin42
« Reply #8 on: 02 March 2014, 22:20:08 »
What about refitting new fuel filter but dont connect the outlet side,then see if there is fuel coming out when pump primes.
« Reply #9 on: 02 March 2014, 22:23:11 »
So.
Its very rich at idle, and quite rich at higher revs. Hence FPR being considered.
Blocked filter? The 3 replacements have all prevented the car starting...  ...though obviously I'm suspicious of something around the filter if only the original one works...
« Reply #10 on: 02 March 2014, 22:24:10 »
I'm sure when he tried the first replacement filter, he confirmed he had a good fuel flow to the injector rail.
  • Auckland
    • Mazda MPV
« Reply #11 on: 02 March 2014, 22:35:55 »
So.
Sorry, didn't explain myself.
Try "partially blocked filter" + bodged FPR that doesn't limit the fuel pressure.
At idle enough fuel gets through for a rich idle.
At full throttle there isn't enough fuel (due to partially blocked filter)
Is the return to the tank OK? (has it been crushed or has someone put a restriction in the pipe perhaps?)
A new filter (with very little resistance) resulting in far too much pressure at the fuel rail.
« Last Edit: 02 March 2014, 22:37:38 by Andy H »
« Reply #12 on: 03 March 2014, 17:55:10 »
Understood, I'll get him to check :y. He was going to check the return anyway for restrictions.
Martin_1962
« Reply #13 on: 03 March 2014, 18:15:44 »
Hyundai, sell for scrap!
« Reply #14 on: 03 March 2014, 19:49:58 »
if it has 4 wheels , sucks air and fuel and pumps out burned exhaust gas.. it doesnt really!
Pages: [1] 2 3  All   Go Up
