Author Topic: Intermittent indicators  (Read 1514 times)
artsoul_no1
  • sidcup, kent
    • Omega CD 2.6 v6 2002
« on: 04 March 2014, 15:10:04 »
Hi all
My indicators were intermittent and from the general concensus online changed the hazard warning switch to a second hand one that seemed to do the trick for a few months. But now it is back doing the same thing.
Is there any thing else to check like a relay? or should i clean the connectors that the hazard switch plugs into, or is it possible that the second switch has gone faulty as well, not sure how common this fault with the hazard switches are.
Any thanks appreciated as its a bit nerve wracking turning off a busy road with indicators that suddenly stop
Many thanks
Dave
Re: Intermittent indicators
« Reply #1 on: 04 March 2014, 18:29:07 »
Repeatedly press the hazard switch about 50 times. See if that helps
artsoul_no1
  • sidcup, kent
« Reply #2 on: 05 March 2014, 14:45:43 »
Thanks for the reply
Is that just something you have to do every now and then as a matter of course regardless of whether its a new switch?
« Reply #3 on: 05 March 2014, 20:07:31 »
I've never had to do it, but I know its worked as a temp fix for others...
Page created in 0.008 seconds with 16 queries.
