Author Topic: Fairly urgent part number help  (Read 2232 times)
« on: 05 March 2014, 10:13:30 »
Please can anyone help by giving me the part numbers for the following bits on a 2000 3.0 V6?
Mucho thanks :y
Thermostat O ring
Water pump O ring
Thermostat coolant transfer pipe O rings
Coolant bridge Doughty Washers
Coolant Bridge bolts
Oil cooler washers (oil pipes to cooler)
Black Sealant
Grey Sealant
Rear coolant transfer pipe (the one that runs along the OS head)
Manifold studs
Manifold Nuts
Downpipe Nuts
Exhaust downpipe to manifold gaskets
Oil filter spin on conversion jobby
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Fairly urgent part number help
« Reply #1 on: 05 March 2014, 11:07:57 »
Mucho thanks :y
Thermostat O ring
Water pump O ring
Black Sealant   90485251
Grey Sealant    93165267
Manifold studs
Manifold Nuts
Downpipe Nuts
Not sure which one is which but the alloy washers and the rubber seal numbers are .............
11076852 and 90409175
« Last Edit: 05 March 2014, 11:12:26 by tigers_gonads »
« Reply #2 on: 05 March 2014, 11:10:09 »
I'm willing to bet that the person behind the parts desk has access to EPC  ::)  ::)  ::)
« Reply #3 on: 05 March 2014, 11:14:31 »
The last few times I've been in, the kid hasn't had a clue what a "coolant bridge" is, and takes up to ten minutes to find each item I want.
I can imagine this list would take him an hour!
Whereas, on a forum where we know these cars very well, I thought it was worth a shot in case anyone had any of the part numbers I was looking for to hand
Nobody is being forced to look anything up :y
« Reply #4 on: 05 March 2014, 11:20:20 »
You could answer a fair few of your questions by reading the guides.
« Reply #5 on: 05 March 2014, 12:14:56 »
I was pulling your leg  ::)  ::)
« Reply #6 on: 05 March 2014, 12:16:59 »
http://www.omegaowners.com/forum/index.php?topic=90588.0
1. 90424578 HOLLOW CHANNEL BOLT FOR COOLER RADIATOR
2. 11076852 METAL COOLER O-RING
3. 93176626 COOLER RADIATOR AND COOLER PLATE (INCLUDES NUTS)
4. 93165267 SEALANT (GREY STUFF (MAY COME IN DIFFERENT PACKAGING))
5. 90409175 O-RING BETWEEN COOLER PLATE AND COOLER RADIATOR
6. 12992646 HOLLOW CHANNEL BOLT FOR COOLER BRIDGE
7. 12992647 COOLER BRIDGE SEAL
ALSO THE FOLLOWING (optional, not pictured)
8. 90502201 THERMOSTAT
9.  9128363 THERMOSTAT O-RING
10. 9129999 COOLANT TRANSFER PIPE O-RING (FEEDS INTO THERMOSTAT HOUSING. ORDER 2 OF THESE)
« Reply #7 on: 05 March 2014, 12:53:22 »
Andy - many thanks! :y :y
Mark - will take a peek :y
