Author Topic: My v6 leak was not a head gasket drip..  (Read 4611 times)
« on: 05 March 2014, 16:52:03 »
It was a bloody head gasket river!!
I will post more pics later, but both head gaskets virtually corroded away bar the firing rings
The engine bay looks a little bare....
SMD
  • London
    • :( nowt
Re: My v6 leak was not a head gasket drip..
« Reply #1 on: 05 March 2014, 16:56:41 »
 :o  is this the project elite?
How many cars do you have again?
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #2 on: 05 March 2014, 17:17:09 »
One. but he changes them like his underwear ;D
Gaffers
« Reply #3 on: 05 March 2014, 17:18:14 »
Back on topic:
I had exactly the same with mine with similar symptoms.  Check the cooling passageways are good, mine were restricting coolant flow and thus required to be exchanged :(
« Reply #4 on: 05 March 2014, 17:29:46 »
A side effect of poor coolant choice perhaps :-\
« Reply #5 on: 05 March 2014, 18:04:14 »
I would say so mate. The coolant was blue :y
« Reply #6 on: 05 March 2014, 18:05:30 »
2. The trusty 2.2 also :y
« Reply #7 on: 05 March 2014, 20:53:40 »
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #8 on: 05 March 2014, 21:18:42 »
I see your keeping busy James, good luck with the project :y
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
vauxlooney
  • southport
    • omega 2.5
« Reply #9 on: 05 March 2014, 21:45:13 »
blue coolant cant be that bad surly? i have not have any problems with it in the past. maybe the car has been ran with water and no anti free at all in past? Given water leaks are quite common and people just top the system back up with water until its fixed it wouldn't be that surprising
« Reply #10 on: 05 March 2014, 21:56:35 »
If it's chemically wrong, not just the colour, it actually becomes quite damaging.
As for topping up with plain water, that's equally asking for trouble on a large scale...
Basically Omega cooling systems react badly to abuse/neglect. I suspect this is a case in point :-\
« Reply #11 on: 06 March 2014, 00:11:59 »
Did you do that outside the wine shop?  :D  ;D
« Reply #12 on: 06 March 2014, 05:41:34 »
Got a eBay bargain, 2 x genuine head gaskets, £10 the pair :y
SMD
  • London
    • :( nowt
« Reply #13 on: 06 March 2014, 06:51:04 »
I thought V6 head gaskets rarely fail? Is this result of poor coolant servicing? I have noticed with past cars service history that coolant, brake fluid and fuel filters often get neglected  >:(
« Reply #14 on: 06 March 2014, 08:22:59 »
Yes.
Many overlook the FACT that antifreeze does much more than stop the coolant freezing.
It also includes corrosion inhibitors which last around 2 years on blue antifreeze and 4 years on long life stuff (often red in colour).
Once the inhibitors become time expired then alloy corrosion and head gasket damage WILL occur (plus oil cooler on the V6).
When you remvoe a head its always easy to see if its been well maintaiend by looking at the coolant passages
