Author Topic: Random miss fire issue when under load at idle  (Read 3926 times)
tOnYoYo
  • Basingstoke
    • Omega Elite 3.2 V6
« on: 09 March 2014, 13:19:13 »
So my 2001 MV6 3.2 has developed a 0300 fault.
It rears it's head when the car is stationary and I slip it into reverse. Sometimes it's immediate, occasionally I have to wait up to 30+ seconds before is start running lumpy.
Yesterday it happened in Drive at some traffic lights and then the engine management light came on and I had to limp home. When I got home and switched the car off and on again, it was fine.
I took this off the engine today and it looks a bit buggered, but I have no idea what it is called:
https://onedrive.live.com/redir?resid=1A23888A15BCD454!539&authkey=!AFin2XA45X9xFJI&v=3&ithint=photo%2c.jpg
Could this be the cause of all my woes? Or is it going to be more complicated that this?
Thanks in advance!
Re: Random miss fire issue when under load at idle
« Reply #1 on: 09 March 2014, 13:26:33 »
Yep! That coil pack is well past retirement age ;D :y
tOnYoYo
  • Basingstoke
« Reply #2 on: 09 March 2014, 13:28:06 »
Thanks PhilRich  :)
I guess the other side is probably past its best too but that one's a pain to remove. The car's done 105k.
Any idea of cost for two of these?  ???
« Last Edit: 09 March 2014, 13:29:52 by tOnYoYo »
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
« Reply #3 on: 09 March 2014, 15:30:40 »
Search for the right ones for your car here. They sell genuine Bosch coil packs.
http://www.vauxhallworldparts.com
chrisgixer
« Reply #4 on: 09 March 2014, 21:41:15 »
Iirc, there where miss fire problems before. ::)
tOnYoYo
  • Basingstoke
« Reply #5 on: 11 March 2014, 14:14:25 »
There seems to be two, and the both supposedly fit. What's the difference between a 12804 and a 12805? Are they just left and right?  ???
martin42
« Reply #6 on: 11 March 2014, 17:29:47 »
They are handed  :y
The Omega Glory
  • Staffordshire
    • Elite Saloon
tOnYoYo
  • Basingstoke
« Reply #8 on: 12 March 2014, 18:59:30 »
I am both baffled and amused by these two seemingly identical items with different colour plugs being priced differently to each other...  ;D
Paddy Flannery
    • 2003 2.6 V6
« Reply #9 on: 12 March 2014, 19:31:10 »
Carparts4less are considerably more expensive than http://www.vauxhallworldparts.com/ for the same Bosch packs.   :-\
tOnYoYo
  • Basingstoke
« Reply #10 on: 12 March 2014, 20:48:15 »
If you stand in front of the car, which bank is on your left? Is it 1-3-5?
Paddy Flannery
    • 2003 2.6 V6
« Reply #11 on: 12 March 2014, 21:01:58 »
Looking into the engine bay, 135 on the left.  :y
tOnYoYo
  • Basingstoke
« Reply #12 on: 12 March 2014, 21:48:36 »
Cool. Thanks!
That's the one in the picture. You think I should try just replacing that one, or just do them both at once?
Paddy Flannery
    • 2003 2.6 V6
« Reply #13 on: 12 March 2014, 22:04:14 »
My 246 is at fault at the moment and I'm only going to change it.
Matter of choice. Do you intend to keep the car ? If you do and you can afford both, then maybe wise to do the 6 plugs, both packs and get the codes cleared while the plenum etc is off.
Hope you cure it !  :y
Paddy Flannery
    • 2003 2.6 V6
« Reply #14 on: 12 March 2014, 22:08:00 »
Other thing I have to consider too is where the water etc is getting in to kill the pack. A known good one only lasted a couple of weeks and she is chugging badly with 0300 and 0302 stored..... Again.
Need to get someone who knows their stuff to do the job for me and seal the wipers/scuttle etc.  :(
