Author Topic: snow foam  (Read 2905 times)
snow foam
« on: 09 March 2014, 22:05:35 »
Anyone use it? If so, what do you use it with? Pressure washer or garden hose type?
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: snow foam
« Reply #1 on: 09 March 2014, 22:07:45 »
You need something like this with the correct connection to your pressure washer.  Link
Re: snow foam
« Reply #2 on: 09 March 2014, 22:10:16 »
Excellent stuff if you buy decent quality .. it "lasts" a long time, remaining "foamy" on the car and softening any dirt. I use an applicator attached to a pressure washer
washer is the Karcher K4, applicator is
EDIT
This is the stuff I use .. :)
http://www.autobritedirect.co.uk/index.php/magifoam.html
« Last Edit: 09 March 2014, 22:13:54 by Entwood »
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
Re: snow foam
« Reply #3 on: 09 March 2014, 22:11:38 »
Soon be Christmas Andy - be able to make full use of it then  ;) ::)
got me coat and i'm gone  ;D
Re: snow foam
« Reply #4 on: 09 March 2014, 22:16:07 »
Cheers lads! I'd seen the Car Plan stuff with the attached hose connection but then read that though the foam was good, the foamer on the bottle was crap.
I will peruse eBay for attachments for my Karcher  :y  :y
Ta
Re: snow foam
« Reply #5 on: 09 March 2014, 22:16:44 »
Even I wash my car more frequently than that  ;) ;)
belldarr
Re: snow foam
« Reply #6 on: 09 March 2014, 23:19:35 »
I use it on each of my cars about once a month, Karcher pressure washer and karcher foam lance with car plan foam which has good reviews - it is a bit of a faff to do it every time and works best if the car is filthy as you are supposed to leave it to run off and drag the dirt and grit with it (usually about 20 mins) then rinse and then you wash the car.
Next you will be using the 2 bucket method of car washing with grit guards and wash mits!!  :)
Darren.
Re: snow foam
« Reply #7 on: 10 March 2014, 05:44:19 »
Next you will be using the 2 bucket method of  .....
is that when you can't find the last bucket you used so use another?  ::)  ;D  ;D
SMD
  • London
    • :( nowt
Re: snow foam
« Reply #8 on: 10 March 2014, 07:06:13 »
Careful Andy, detailing is more addictive than crack! :'(
Re: snow foam
« Reply #9 on: 10 March 2014, 09:26:33 »
 ;D  ;D  ;D Believe me ........ I'm not about to start detailing  :y
