Author Topic: Heavy vibration when braking  (Read 3746 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 10 March 2014, 14:52:40 »
Took the car for a nice run down to Skeggy on Sunday.
Now I seem to have picked up another problem  :(
Sometimes, when I brake lightly, i'm getting a harsh vibration though the brake peddle and the steering wheel.
If I press harder, the vibration disappears.
The car does stop in a straight line.
I know the front discs have seen better days but there is no sign of warping or lip on the outer edge on the disc.
The front pads are Mintex 1144's and have done about 6000 miles on them with plenty of meat left.
Any ideas ?
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Heavy vibration when braking
« Reply #1 on: 10 March 2014, 14:55:01 »
wheel bearing?  :-\
martin42
« Reply #2 on: 10 March 2014, 15:02:24 »
Warped front discs.
« Reply #3 on: 10 March 2014, 15:05:59 »
What state are the front wishbone bushes in?
« Reply #4 on: 10 March 2014, 15:10:59 »
Out of interest, what condition are the inside edges of the disks in?
« Reply #5 on: 10 March 2014, 15:11:37 »
Although in this case, I'd be checking wishbone bushes.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #6 on: 10 March 2014, 15:24:54 »
Thanks for that lot  :)
I've got to pop out so i'll have a poke around later if its still light outside  :y
Just out of interest, when I got the car, it was pulling to one side but a good clean of the calliper's and new pads sorted it out.
Iirc, these are Lucas calliper's. Do Lucas sell a service kit for them so I can strip them down and do the job properly ?
chrisgixer
« Reply #7 on: 10 March 2014, 16:21:41 »
Vauxhaul might.
Inner edge of disc rusted if it's the same each time, or wishbones bushes failed which tends to give a random "flap" from the steering like a tank slapper. More of a wobble.
I'd guess at inside edge of discs rusted but could be either.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #8 on: 10 March 2014, 16:26:21 »
It's really unlikely to be a caliper problem. Wishbone bushes would be top of my list, an examination of the steering linkage is always a good idea, and knackered topmounts/strut bearings would be worth considering. Actually, if you suspect the latter, inspecting them probably isn't worth the hassle; replacement would be the way to go.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #9 on: 10 March 2014, 17:36:32 »
Vauxhaul might.
Spot on, well the first inch or so is scored :y :y
What could be causing this ?
I'll poke the wishbones with my scaffold pipe when I find it tomorrow  ::)
Am I right in thinking that to check the wishbones, the car needs to have its weight on the wheels ?
« Reply #10 on: 10 March 2014, 17:41:59 »
Play is better identified with no weight on the wheels :y
chrisgixer
« Reply #11 on: 10 March 2014, 17:46:53 »
Re discs, they all do it.
Heat resistant paint greatly improves matters though. Ebc dimpled/grooved discs last quite well. Not sure they take major punishment though.
So painting Gm discs would help the rust issue I'm fairly sure.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #12 on: 10 March 2014, 17:59:52 »
50/50 and guess which one I choose  ::) ;D
Cheers Al  :)
« Reply #13 on: 10 March 2014, 18:25:25 »
I'm beginning to kind I need to be a chav, as due to less use (by me), mine keep going the same way before I've worn the tinkers out.
I'll get meself a baseball cap, coz itz ware itz at, init?
chrisgixer
« Reply #14 on: 10 March 2014, 18:54:58 »
Oh shutup ;D
