Author Topic: Brake pipe to caliper  (Read 3592 times)
« on: 10 March 2014, 18:28:37 »
Guess its a banjo, with 2 copper washers? Washers should be replaced rather than reused?
Re: Brake pipe to caliper
« Reply #1 on: 10 March 2014, 18:33:37 »
 ??? Can't remember  ???
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 10 March 2014, 18:42:03 »
If the washers look good heat them up and quench to anneal,good to go again then :y
other rides
« Reply #3 on: 10 March 2014, 19:11:10 »
That requires tools. For 2 or 3 quid, I'll just buy some if they cant be reused as-is :)
« Reply #4 on: 10 March 2014, 19:23:13 »
I should point out this is rear caliper, and I can't find part number for rear. Can anyone remember if it is a banjo type setup?
« Reply #5 on: 10 March 2014, 19:24:56 »
Nope, rigid brake pipe screws straight into caliper :y
Front is banjo and two washer jobbie on the end of the flexible brake hose... ::)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 10 March 2014, 19:26:36 »
Take one to your local hydraulics supplier where 2 or 3 quid will buy enough for all of us to use for the rest of these cars lifetimes. As for tools, pliers and the gas stove should do the job.
chrisgixer
« Reply #8 on: 10 March 2014, 19:26:51 »
Google is your friend btw. Always worth a search before posting. ;) ;D
« Reply #9 on: 10 March 2014, 19:28:50 »
TB isn't allowed gas... :D Or pliers.
Now look what you've started ::)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #10 on: 10 March 2014, 19:29:55 »
As in:
« Reply #11 on: 10 March 2014, 19:30:27 »
See... just like that :y
« Reply #12 on: 10 March 2014, 19:47:13 »
How does it seal? A taper?
chrisgixer
« Reply #13 on: 10 March 2014, 19:55:40 »
Olive on a flaired pipe end iirc. Basic plumbing type thing.
« Reply #14 on: 10 March 2014, 19:56:18 »
And no need to change olive?
