Autobox level plug.
Started by Bigron, 12 March 2014, 21:35:36
Bigron
I want to spend the minimum of time under the car (fat, awkward location, etc) so if anyone could tell me what size socket I need to for the level plug, that would save me a little aggro, please?
Ron.
Stemo
13mm, according to the maintenance guide.....you'll find that in...maintenance guides.. ;D
Bigron
Shackeng
Unless.............like some of them (one of mine actually ::)), it's on so tight that the flats get rounded, so it gets reduced to 12mm! :y
Ron sorry I overlooked your Pm, I've had loads going on
What are the exact additives that are in the box?
Webby the Bear
Mine was on FT!!!!!
Get a 13mm six sided socket and medium sized breaker bar. That worked best for me. :)
RIP Paul Lovejoy
Bigron
Thanks for your comments, gents; very helpful as usual.
The plug shouldn't be as tight as the proverbial duck's arse as I've had my garage top up the ATF a few times recently (gearbox leak), but now I want to do it myself due to pension-limited finances!
I just wanted to have everything ready to hand so as to spend the minimum amount of time under the car.....
Ron.
tigers_gonads
Don't forget to check the level with the engine running  ;)
Bigron
Thanks for the reminder, TG. What are the consequences of over-filling the gearbox? As my driveway isn't level, I can't guarantee to get the level right.
Ron.
tigers_gonads
Quote from: Bigron on 13 March 2014, 10:24:51
Ron.
I can't see it been to much of a problem if its only a little over because iirc, the box does have a pressure vent pipe which ends up behind the engine somewhere  :-\
Tbh, I did mine yesterday with the back end on 2 Halfords specials ramps and the front end up on a couple of stands with no problems to a fat barstid like myself  ;D ;D
If you have the dosh for a couple of gallons of the oil, i'd drop the sumps, unbolt the filter (black plate with 3 13mm bolts) and give it a good clean with paraffin or some cheap white spirit first  :y
I did all that to mine yesterday including dumping 2 gallon of hot gearbox oil on my head  ;D ;D ;D
Cleaned the rubber seals up with some brake cleaner and smeared some instant gasket on the sump.
Put it back together and filled it up  :y
Went for a drive this morning .............. no leaks and it changes gear much better  :y :y
Bigron
Thanks again, TG.
Is it an essential part of the procedure to anoint yourself with hot oil? I would like to follow your instructions to the letter, but if I could perhaps omit that stage?
According to my garage, the leak is coming from what looks like a blanking plate (but isn't) towards the rear of the bell-housing; does that sound reasonable?
Would replacing the ATF recondition the seals, as Wynn's and Lucas additives have not?
Sorry for all the questions.
Ron.
Quote from: Bigron on 13 March 2014, 10:54:06.....
Is it AT that's leaking or is it engine oil from a fubar'd rear crank shaft seal?  :-\
chrisgixer
Quote from: Andy B on 13 March 2014, 10:57:15
What's AT Andy? Is it ATF without the F?
Bigron
Definitely ATF, Andy; after 2-3 weeks the gearbox starts to play up and requires a couple of litres of ATF to refill it!
The engine oil stays at the correct level throughout.
Ron.
Quote from: chrisgixer on 13 March 2014, 10:59:28
Correct!  :y  :y  :y
