Author Topic: V6 - 3.0 misfire /rough running  (Read 2013 times)
idwal
  • telscombe cliffs near brighton
    • Mv6 estate (2000) Lpg
« on: 14 March 2014, 17:10:12 »
Fault started yesterday
Rough running / misfire on start up and when running
Paper clip test done running.  Code 1-9 only
Me think coil pack?
Car has done 125000.
Any other suggestions
Thanks
Ken
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: V6 - 3.0 misfire /rough running
« Reply #1 on: 14 March 2014, 17:14:05 »
Hello Ken,
have you checked the plug holes to make sure your cam covers haven't leaked and buggered your coil packs/spark plugs?
HTH
Alex
V8!!!!
idwal
« Reply #2 on: 14 March 2014, 17:21:31 »
Not yet
Cam covers done about 1 1/2 - 2 years ago
ngrainqey
  • rotherham
« Reply #3 on: 14 March 2014, 17:24:00 »
Righto, tbh still worth checking imho - coilpacks are expensive to have it go again
Alex
V8!!!!
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #4 on: 14 March 2014, 17:37:53 »
Code 19 is a crank sensor fault code, unless the codes were read with the engine off
first check is to see if the plug wells are full of oil, if so the cam covers have failed due to blocked breathers, or the gaskets were not gen gm, or the wrong sealant was used.
Jaguar XJ6
idwal
« Reply #5 on: 14 March 2014, 21:20:29 »
If it is the crank sensor do I need to get from dealer or parts store?
ngrainqey
  • rotherham
« Reply #6 on: 14 March 2014, 21:35:50 »
probably dealer, AndyC can get you dealer discount an posted from bury Vx. think there are two different connectors for crank sensors so easier to just get from dealers unless you take the old sensor to such as eurocarparts
V8!!!!
