Zero toe
Started by chrisgixer, 16 March 2014, 10:52:51
chrisgixer
How many miles on the tyres?
Webby the Bear
About 5k miles ago :)
RIP Paul Lovejoy
Quote from: Taxi Al on 17 March 2014, 12:34:01
I wonder then from what you describe if it's not simply a side effect of cornering speed :-\
Having followed Chris to his house after the curry I can confirm that he does like to corner rather quickly indeed.. I only caught up as I was in the M3 - poor Kev in the MX5 disappeared into the distance behind us.. ;D
Hooligans, these Omega owners.
Out of interest, Chris, what pressure do you run the fronts at? Just wondering if the tyre is 'rolling over' under hard cornering - although you'd have to be driving like you were on Saturday an awful lot of the time for that to be the cause..
You noticed that too ;D
Does rather like his tyres soft as well...
Quote from: aaronjb on 17 March 2014, 13:20:40poor Kev in the MX5 disappeared into the distance behind us.. ;D
<cough!> Ok, I was in the MX-5, I'll grant you that, but, after 4 Cobras... ::)
Quote from: Kevin Wood on 17 March 2014, 13:37:13
;D Apologies Kevin, I'll let you off for falling behind, then ;)
Quote from: aaronjb on 17 March 2014, 14:10:44
;D just you wait until Mrs Kw reads this...
chrisgixer
Quote from: Webby the Bear on 17 March 2014, 13:19:58
Shouldn't show yet. If the settings are in range then the wear will be within the life of the tyre. If there was wear after 5k that would be bad.
But if your concerned get them to sort it. ;)
chrisgixer
I have run these at 28 psi. Same wear. Nice compliant ride.
Current set are at 34psi. Carrying some load and the roads are buggered.
chrisgixer
Quote from: Taxi Al on 17 March 2014, 13:25:08
32psi standard Al. Nobody runs max load pressures all the time. Ride is way too harsh.
....unless your a Taxi driver. ::) no wonder they pootle about everywhere
 ;D not known for pootling anywhere, me ::)
Stemo
chrisgixer
It's ok, we got out and pushed waited at the last too roundabouts so our Kev could catch up. Bless him. ;) ;D
chrisgixer
Webby the Bear
Quote from: chrisgixer on 17 March 2014, 14:59:34
Thanks Chris.
on the contrary i'm not concerned at all. No wear equals no problem in my mind :)
RIP Paul Lovejoy
