Zero toe
Started by chrisgixer, 16 March 2014, 10:52:51
chrisgixer
We know the oe toe setting, of -0.10 combined(-0.05 each side), is designed to account for oe bushes to avoid excess toe out under braking. Possibly going passed zero toe on the brakes into a minus figure.
What effect do Polly bushes have on the toe figures. A lot of members have Polly fronts. There are also some experimental rearward bushes on some members cars.
Mine has front Poly fitted, and oe rubber gm rearward bushes, but still has a standard toe setting.
Reason for asking is, camber is set to -1.15. (0.05 more amber than the standard -1.10) yet I'm still getting more outside edge shoulder wear than on the inner edge.
Is the toe causing it/will a lesser toe setting help?....and if so how much toe to dial in given a full set of poly bushes gives a recommended toe setting of zero toe?
Front tyres are 245 40 18.
Stemo
Don't know mate.  ;D
chrisgixer
chrisgixer
Stemo
chrisgixer
NUUUURSE, HE'S OUT OF GEN CHAT AGAIN.
...or are they all out on strike? Take your meds Esta. Quick.
pscocoa
Is the Polly front part of the Parrot system? If so I would give it my toe end.
Stemo
Quote from: chrisgixer on 16 March 2014, 11:47:15
I've had my Viagra this morning, thank you. :-*
Stemo
Quote from: pscocoa on 16 March 2014, 11:48:31
Don't you start. He'll cry and leave. ;D
chrisgixer
Quote from: STEMO on 16 March 2014, 11:49:46
Post count is getting a bit high...
....isn't it Esta. 593 ? ;D
Stemo
Quote from: chrisgixer on 16 March 2014, 11:52:03
So, what are you saying? One of us has a life?  ;D
chrisgixer
Quote from: STEMO on 16 March 2014, 11:53:20
Several lives in your case, remember the pictures. :o
Stemo
Quote from: chrisgixer on 16 March 2014, 11:55:30
You've hijacked your own thread, stupid.  ;D
chrisgixer
There was a time when admin would put you over their knee.
...ah, I see ! ;D
