If a tyre has run flat....
Started by chrisgixer, 17 March 2014, 16:35:10
pscocoa
There's gratitude for you - I warned you Al - now see what you have done
chrisgixer
Quote from: Taxi Al on 17 March 2014, 16:56:06
;D pmsl
Have a pair of Acceleras in that size if any use :-\
Thanks Al, nice thought but its best to get it sorted. New tyre going on tomorrow. (£157)
chrisgixer
So would tpms have helped in this situation?
Might of saved the tyre, if repairable, which it was.
Quote from: chrisgixer on 17 March 2014, 17:17:05
Depends how long it took to deflate .... if it went down slowly, overheated, then failed completely, TPMS might have spotted the initial loss of pressure and warned you before the overheating started, a decent TPMS would certainly have spotted the overheating. If you had pulled over then it probably would be repairable.
However, if it punctured and deflated in less than, say a minute, so it went down fast, then by the time TPMS had warned you, you would have felt it anyway.
The damage is done by driving on the flat tyre ... TPMS cannot do a thing about that as it is your decision to stop or not ..... :)
Depends on what caused the puncture in the first place...
What Mr E said... ::)
Quote from: chrisgixer on 17 March 2014, 17:10:33
;D pmsl
:o :o :o :o :o
I paid a lot less than that for 4 tyres  ;D
chrisgixer
Quote from: tunnie on 17 March 2014, 17:27:19
;D pmsl
:o :o :o :o :o
Tunnie, YOU dont actually NEED tyres AT ALL! :)
Quote from: chrisgixer on 17 March 2014, 16:35:10
...and there's a hand full of rubber granules rolling around inside as a result, is it buggered?
Depends how much. More than a quarter of a thimbleful in the entire tyre, I'd say BF'd.  Given the way you drive, not worth the risk anyway.
If you're trying hard enough, at 8k, the tyre should be almost spent anyway
;D pmsl
:o :o :o :o :o
Remember, I've driven all Omegas in your household...  ...and your folks know its wise to spend a tad more for a better tyre ::)
Chris, although you can check the tire physically , I wouldnt risk any passenger or myself .. buy a new one imo..
Quote from: cem on 17 March 2014, 19:02:27
Your English is great cem :y. But they are called tyres here ;D
Quote from: TheBoy on 17 March 2014, 19:03:55
Your English is great cem :y . But they are called tyres here ;D
I thought the reverse was true :-\ ok then :y
chrisgixer
I rekon it's just over a palm full if rubber.
Cem as said, new tyre going on tomorrow.
TB. Previous pair of 265 rears did 14k. So 6k to go.
Quote from: chrisgixer on 17 March 2014, 19:18:14
Yeah, well and truly shagged. Whats done is done, no point crying over it, you know the solution (and are doing that tomorrow) :)
On the bright side, over half worn, and the 2nd half is never as satisfying.
