If a tyre has run flat....
Started by chrisgixer, 17 March 2014, 16:35:10
chrisgixer
But.... it's only one rear tyre, not a pair. :(
Quote from: chrisgixer on 17 March 2014, 19:30:25
You know the answer to that  :'(
chrisgixer
chrisgixer
Listen to em. Pair of experts together. ;D
Quote from: TheBoy on 17 March 2014, 20:53:14
Quote from: cem on 17 March 2014, 19:47:55
Quote from: chrisgixer on 17 March 2014, 19:33:24
Yes, £314
not necessary..
I would do the axle pair
either the equal olders on the rear with single new on the front left (passenger side for Uk) or pair of cheaper non-run flat.. imo
or some sanding and heating will do the job ;D
Quote from: cem on 17 March 2014, 22:09:09
Off to BP, then. :y
Yes, £314
not necessary..
Agreed - otherwise like fitting only one new spring or only one new wishbone ::)
chrisgixer
Yes, £314
not necessary..
either the equal olders on the rear with single new on the front left.......
Rears are 265 cem. They will not fit on the front.
Quote from: chrisgixer on 17 March 2014, 23:18:42
Yes, £314
not necessary..
They will after Cems sanded them "a bit" .....  :)
I think you should get a new WIM'ed spare as well, just to cover all your bases.....  :-\
Auto Addict
If it's a run flat, just keep driving it :y
I like red cars
chrisgixer
Quote from: Auto Addict on 18 March 2014, 06:25:01
Do Birds do tyre weld ? Asda maybe?
