Author Topic: Washer fluid level warning!  (Read 2645 times)
cd 2.2
« on: 20 March 2014, 22:08:53 »
As per post, I'm getting a very sporadic washer fluid level warning on the dash (and the check light which is annoying)! This happens intermittently and it doesn't matter how much is in the bottle  ??? Tonight I took the sensor out as I'm lucky to have a F/L mig and as soon as you open the bonnet you can see it. The thing was covered in a green algae  type gunge, so I promptly  cleaned it up well and re fitted the sensor ... Now it's worse than ever  ;D I'm guessing that the sensor is buggered but I thought I would ask for other opinions to confirm my suspicions before just going and getting a new one!
After being told about the no screenwash thing being a very bad idea I immediately went on the search for something suitable. Now I use Prestone All Season Screen Wash  :) This stuff is amazing, it has something in it that repels the rain water on the screen so even when driving in rain that would usually require wipers on speed 1 you can comfortably get away with intermittent! Only down side is that there isn't really a smell to it as such so a bit boring on that front
Re: Washer fluid level warning!
« Reply #1 on: 21 March 2014, 07:53:50 »
Easy way to check if sensor or wiring is to unplug, short out the wiring with a paperclip (insulate it though, to stop it touching anything else, and drive around for a day or so. If that cures it, you know its sensor.
9 times out of 10, its the sensor, but I have seen corrosion in those front looms before.
« Reply #2 on: 21 March 2014, 07:54:40 »
Oh, and sensors are reliable enough to use 2nd hand. No idea how much from a dealer (bet its dealer only part).
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #3 on: 21 March 2014, 07:57:22 »
Can you help an ignoramus please - where is the sensor?
Ron.
« Reply #4 on: 21 March 2014, 08:03:30 »
Ron.
Facelift or PFL?
« Reply #5 on: 21 March 2014, 08:04:56 »
FL - open bonnet, look down near where washer filler goes into washer bottle, and you can see sensor sticking out backwards.
PFL - Easier to see with bumper off, but it sticks out sideways on the passenger (RHD) side of bottle.
Bigron
  • Witham, Essex
« Reply #6 on: 21 March 2014, 08:05:17 »
Facelift - 2.6 V6 petrol saloon, '51 reg.
Bigron
  • Witham, Essex
« Reply #7 on: 21 March 2014, 08:08:33 »
Our messages crossed, but thanks a lot - simpler than I imagined!
I will look out for a sensor next time I'm near a breakers, because I occasionally get false alerts, even after I've just filled the screenwash.
Ron.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #8 on: 21 March 2014, 08:49:10 »
Think the new tanks are around £30 from main dealer. :y
cd 2.2
« Reply #9 on: 21 March 2014, 08:52:52 »
going to bridge it today and see if it stays off ... has to really for the stupid new M.O.T rules  >:( why would it matter if you had a warning lamp on anyway??
« Reply #10 on: 21 March 2014, 12:29:20 »
Got a few known good wash level sensors here if needed :)
« Reply #11 on: 21 March 2014, 12:43:44 »
Ron.
Left of centre
cd 2.2
« Reply #12 on: 21 March 2014, 23:28:23 »
I was told by my local Vx dealer today this lovely piece of information ... The sensor is not available to purchase on it's own from Vx anymore. If however, you need a switch desperately, They can sell you an entire "tank" which "includes" the sensor .... This item is currently £39 + V.a.t and is widely stocked in the u.k dealerships
This is for a FL like mine not a pre FL
« Reply #13 on: 22 March 2014, 11:26:10 »
This for the washer reservoir or the expansion tank ???
cd 2.2
« Reply #14 on: 22 March 2014, 13:53:33 »
for the screen wash tank as pictured above  :y
