Author Topic: Airbag light on  (Read 3472 times)
Airbag light on
« on: 28 March 2014, 20:29:44 »
This decided to come on today >:(
Checked and dfouble ckecked the seat plugs, nothing obviously amiss :-\
Guessing it needs a tech 2 session or similar to reset/code read to pin point the faulty circuit :-\
Re: Airbag light on
« Reply #1 on: 28 March 2014, 20:30:48 »
ideally, yes. Poke and hope usually isn't efficient
Re: Airbag light on
« Reply #2 on: 28 March 2014, 20:33:07 »
:'( thought as much...
Re: Airbag light on
« Reply #3 on: 28 March 2014, 20:53:14 »
The  light would stay on though until cleared even if you fixed the fault  :(
Re: Airbag light on
« Reply #4 on: 28 March 2014, 21:19:11 »
The cause is likely one of two things...
A disturbed plug at the passenger seat...
Trying to start the car having forgotten that both large plugs in the passenger footwell were unplugged ::)
Re: Airbag light on
« Reply #5 on: 28 March 2014, 23:14:55 »
Ooops!  ::)
Re: Airbag light on
« Reply #6 on: 29 March 2014, 00:00:54 »
The embarrassing thing is I was trying on and off for twenty minutes before I twigged ;D
But then I did also try to change the cambelt with the car in gear :-X
Re: Airbag light on
« Reply #7 on: 29 March 2014, 00:17:19 »
If you were closer I'm sure I could turn the light off for you  ;)
The clue was ..... you were trying to run yourself over. ...... if only you had a more appropriate gearbox  ;) ;)
Re: Airbag light on
« Reply #8 on: 29 March 2014, 00:25:34 »
 ;D :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Airbag light on
« Reply #9 on: 29 March 2014, 00:41:47 »
Ooops!  ::)
Yep,that would do the trick ::)
other rides
Re: Airbag light on
« Reply #10 on: 29 March 2014, 17:19:21 »
Sometimes they go out (almost immediately) on their own, once fixed.
Don't suppose you get many fares to Brackley ;D
Re: Airbag light on
« Reply #11 on: 29 March 2014, 19:28:09 »
When are you off to the airport again...;D
Taking it for a run tomorrow so shall report back then :y
Re: Airbag light on
« Reply #12 on: 30 March 2014, 19:16:16 »
130 miles and still on ::)
Re: Airbag light on
« Reply #13 on: 30 March 2014, 19:55:14 »
Fair to say either the fault still exists, or is one of those pesky ones that needs clearing.
Re: Airbag light on
« Reply #14 on: 30 March 2014, 19:56:20 »
I think the useless student is back in Brakkers next weekend. I wonder if that means a curry opportunity exists  :-X
Page created in 0.23 seconds with 16 queries.
