Author Topic: Spare vacuum hose V6 disappeating into lower right wing  (Read 978 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
X168JAT 2.5 petrol manual estate
Gentlemen, please forgive me, I asked this question before when changing the exhaust manifold on another 2.5 estate. Now I am changing the windscreen wiper motor assembly. This time I have a hose emerging from right lower wing, rising into a straight coupling, then ending in a right angle rubber joint. Where should it go? I think last time it was a vacuum purge hose.
terry paget
    • 3 Astras 2 Vectra
Re: Spare vacuum hose V6 disappeating into lower right wing
« Reply #1 on: 29 March 2014, 17:13:04 »
Answering my own question, the left hand of the two central small hoses from the breather unit atop the plenum is unattached. Its hose is the same size as the connector on the end of the hose from the lower RH wing . Now all I need is a length of vacuum hose and I can join the two. Problem solved.
« Reply #2 on: 29 March 2014, 19:31:47 »
They should join via the purge valve ::)
