Author Topic: Crank sensor?  (Read 4539 times)
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
Crank sensor?
« on: 29 March 2014, 21:43:38 »
Just checking this makes sense ...
Bit of a nasty turn this evening. Came over the crest of a hill on a twisty-turny lane and the engine just died. Good job I'd been to the toilet before setting off as it was a hairy descent with heavy brakes and heavier steering. Refused to restart. Engine spun but nothing else. No faults codes stored but 2 pending faults: P0705 (gearbox) and P0725 (crank sensor). Fiddled for ages - nothing. Then, 2 hours later it just started. Drove home and almost made it when it died again. Pushed it the last bit home.
Certainly I can see if the crank sensor failed that would stop the engine PDQ. Why only a pending fault though? Presumably the fact it started after a rest infers heat is causing the failure? Is that what you'd expect if the crank-sensor needs replacing?
Work is the curse of the drinking classes (Oscar Wilde)
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Crank sensor?
« Reply #1 on: 29 March 2014, 22:49:38 »
What engine have you got,
pls update your profile as it will stop others asking, but it sounds like crank senor fault, but dependant to engine it could also be cam sensor. :y
Jaguar XJ6
symes
  • oxford
    • R reg 940 volvo
Re: Crank sensor?
« Reply #2 on: 29 March 2014, 22:52:48 »
+1 :y :y
Re: Crank sensor?
« Reply #3 on: 29 March 2014, 22:57:23 »
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0725 Engine Speed input Circuit Malfunction
Whilst the second one "could" be crank sensor related .. the first one is more likely to be a dirty selector switch
A crank sensor failure  is P0019 or P0335, all P07** are transmission codes
http://www.obd-codes.com/trouble_codes/
« Last Edit: 29 March 2014, 23:00:41 by Entwood »
cd 2.2
Re: Crank sensor?
« Reply #4 on: 30 March 2014, 02:51:39 »
The gearbox selector switch is a cringe worthy £300 give or take a little from Vx ... I only know this as my dad had one fitted last year when his gearbox selector in the car went all christmas tree on him! Apparently this is the most common sign of a failed selector switch and cleaning them rarely achieves anything other than making a broken unit look very clean while remaining broken in my own experience (but got to be worth a try)
Grrrrrr
  • Buckinghamshire
Re: Crank sensor?
« Reply #5 on: 30 March 2014, 10:45:18 »
That's weird. My profile used to have both my cars. Where did that go? Lost in migration, perhaps.
It is the 2.6 CDX (auto, obviously!)
Grrrrrr
  • Buckinghamshire
Re: Crank sensor?
« Reply #6 on: 30 March 2014, 10:52:19 »
Seeing as it isn't raining and my mother has the little one I think I'll go out and have a fiddle for a bit.
Half-temped to see if I can just replace the wires on the crank-sensor. There's probably only 2?
martin42
Re: Crank sensor?
« Reply #7 on: 30 March 2014, 10:55:15 »
Totally wasting your time doing that,just go and buy a new vx sensor,replacing wires isnt going to do a thing...........
Grrrrrr
  • Buckinghamshire
Re: Crank sensor?
« Reply #8 on: 30 March 2014, 11:00:28 »
Looks like they're only £30 so you're probably right. Bet the stealers has a whole shelf ready and waiting judging from half the threads on here.
martin42
Re: Crank sensor?
« Reply #9 on: 30 March 2014, 11:03:56 »
Dont use an aftermarket sensor,they dont last,go to vx where you will get the correct 1 for the car
Re: Crank sensor?
« Reply #10 on: 30 March 2014, 11:54:59 »
Use a genuine sensor if changing V6 crank sensor.
The symptoms match the crank sensor failure, although the codes do not - I'd expect a 0335.
Re: Crank sensor?
« Reply #11 on: 30 March 2014, 11:57:02 »
tut tut, you should know better...
2.5/3.0 (and pre 1996 2.0) crank sensor faultcode is 19, not P0019 ::)
later 2.0/2.2/2.6/3.2 crank sensor faultcode is P0335 :y
:P
Re: Crank sensor?
« Reply #12 on: 30 March 2014, 14:05:31 »
:P
It might be on the paperclip/pedal checks ... but on a code reader ?? I guess as the non-DBW cars are not fully OBDII compliant a code reader might give incorrect info when used on those cars
I simply went by  http://www.obd-codes.com/trouble_codes .. which I accept is for OBDII cars
Re: Crank sensor?
« Reply #13 on: 30 March 2014, 14:09:09 »
:P
Its 19 on any code reader :)
That website is fairly poor TBH, hence we've provided our own lists. Remember, for many codes (not this one), the code alone is not enough, as the same code can cover multiple faults :)
Grrrrrr
  • Buckinghamshire
Re: Crank sensor?
« Reply #14 on: 30 March 2014, 21:08:48 »
Yes, codes can always be a little obscure. For me the engine timing and gearbox all point at no signal. The fact none were logged as faults but only pending faults seems to imply no definitive code was stored. I'll clear the faults and see if they recur. Not keen on going out and getting dumped somewhere though.
Sensor itself looks easy to get to but the plug I could see at the back of the engine didn't look anything like the one in the maintenance guide. Other end goes into near-side bank of cylinders though so guess it must be the connector? I took a picture but had forgotten you cannot upload directly into one of these messages.
