Pages: [1] 2 3  All   Go Down
Author Topic: Very high current relay  (Read 5145 times)
« on: 30 March 2014, 19:32:00 »
Mate of mine has a project where they need to test if they can get several hundred amps down a bit of coax for a very short period of time, and asked me if I knew of an automotive relay man enough. Starter solenoid was best I could think of, but as built into most starters, makes it a bit cumbersome/bulky.
Initial test is going to be at 12v (hence automotive relays considered), but ultimately will go up into the kV range if tests are positive, and this is when big money will need to be spent. But for now, we're looking for a cheap-as-chips solution to prove the cable can withstand the huge currents required.
Re: Very high current relay
« Reply #2 on: 30 March 2014, 20:02:20 »
Come on think old school,like this
http://www.ebay.co.uk/itm/like/400398269358?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=t&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108&ff19=0
We had, but thought that those crappy old solenoids, which didn't hold up too well at the time, only turned over poxy little engines, thus low rated. Do you know what they are rated at? Looking in region of 500-900A
hoofing it
« Reply #3 on: 30 March 2014, 20:07:23 »
The biggest relay I have found is 100amp which I used in a home made split charge system on my camper van.
« Reply #4 on: 30 March 2014, 20:08:54 »
Do they know what they are doing?
A relay or contactor will not give you a controlled pulse period, the currents they are talking will only give at a guess a matter of ms before the core is fried.
It needs a silicon device such as an IGBT
« Reply #5 on: 30 March 2014, 20:14:40 »
Mostly, yes. There is a concern about timing accuracy of relays or electro-mechanical switching, but at this stage, low cost experimentation if needed to see if the coax will handle that sort of current, before proper money is spent. 900A relays are readily available, but are approx. £2k a pop, too expensive for an early trial.
As I understand it, it needs a 20mS test at 500-900A for the first stage of the trial.
  • Auckland
    • Mazda MPV
« Reply #6 on: 30 March 2014, 20:32:20 »
Specialist equipment is available for testing switchgear.
http://www.trtest.com/page.php?cid=21
http://www.megger.com/uk/Products/ProductDetails.php?ID=1563&Description=ingvar
High currents can cause things to go pop in a quite exciting manner. Add in high voltages and it gets properly dangerous.
Kit like this would usually be hired when required.
« Reply #7 on: 30 March 2014, 20:53:55 »
I doubt you'll find anything mechanical that can provide a pulse that fast at that current, and I'd be very worried about the contacts welding, especially if your current source can deliver significant continuous power (i.e. you're not just discharging a big cap). Solid state will be the way to go, I'm sure.
You might want to google "can crusher" designs - e.g.:http://www.powerlabs.org/pssecc.htm
« Reply #8 on: 30 March 2014, 21:12:44 »
.. and if it only needs to conduct for 20ms with a low repetition rate, some fairly modest semiconductor devices might well do the job provided they are switched hard enough to avoid too much dissipation.
« Reply #9 on: 30 March 2014, 21:20:42 »
As I understand it, this test doesn't involve any duty cycle, its a one off test to prove the cable doesn't fail, as the cable manufacturer (understandably) has no specifications related to this type of use.
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #10 on: 30 March 2014, 21:31:47 »
Sounds like an ideal test to do in your new garage. What could possibly go wrong?  ::) :o :o :o :o
chrisgixer
« Reply #11 on: 30 March 2014, 21:56:50 »
It's ok, he's borrowed a pressure washer, and presumably a hose, so he won't need the fire brigade this time at least. Smart puppy see. ;)
  • Auckland
    • Mazda MPV
« Reply #12 on: 30 March 2014, 22:04:26 »
It will fail. Why would anyone expect otherwise  :-\
« Reply #13 on: 30 March 2014, 22:06:57 »
It is believed it won't...
« Reply #14 on: 30 March 2014, 22:07:35 »
Bank of big capacitors that you charge to the required pulse energy, then you might well get away with using a relay / starter solenoid to discharge them into the load? You'll need some way of capturing the voltage and current waveforms to verify what actually went into the load.
Or.. for a one-off, find a test house who have a facility for this type of testing and pay for the test instead of the hardware?
Not sure where you'd go, but there'll be someone who can do it, I'm sure.
Pages: [1] 2 3  All   Go Up
