Pages: [1] 2 3  All   Go Down
Author Topic: ABS and TC lights sometimes on sometimes off  (Read 8428 times)
Kate
  • Cornwall
    • Drives people mad
« on: 31 March 2014, 20:55:15 »
Moved to Cornwall yesterday. About half way there, while the cruise control was engaged, the abs and tc lights came on. The cruise control went off and the speedo went to zero. After about 30 miles the lights went out and the speedo started working again. ::)
Since then the lights are sometimes on, sometimes off.
Just had a used abs ecu fitted recently.
Any idea what the fault might be?
Thanks very much. :y
wiliferus
  • Reading
    • 2003 2.6 CDX Saloon Auto
Re: ABS and TC lights sometimes on sometimes off
« Reply #1 on: 31 March 2014, 21:00:20 »
I'm very much a Mig noob, but my guess would be a wheel speed sensor to knock out all those three things.
I'm sure some who knows a lot more will be along shortly... :y
« Reply #2 on: 31 March 2014, 21:16:22 »
Sounds like the new ecu isn't far behind the old one :'(
If you still have the old one, send it away to be fixed sharpish :y
« Reply #3 on: 31 March 2014, 21:16:55 »
I'd say you need to be looking out for another ABS ECU  :(
« Reply #4 on: 31 March 2014, 21:17:30 »
MTF Mr B ;D
« Reply #5 on: 31 March 2014, 21:19:59 »
MTF Mr B ;D
That's over my head ......  ???
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #6 on: 31 March 2014, 21:20:51 »
I had a similar fault some years ago. I changed ABS ECUs several times, fault persisted. It turned out to be rear right hand reluctor ring split and wandering about on the half shaft, in and out of alignment with the sensor.Worth a look. I cured it by gluing it in place with Araldite. I have pics if you think it likely.
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #7 on: 31 March 2014, 21:30:31 »
Terry can you please put pics up , just for understanding thanks :y
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
« Reply #8 on: 31 March 2014, 21:35:53 »
On the drive shaft ie from diff to rear wheel, there's a castellated ring .... that's the reluctor ring that the ABS sensors look at  :y
« Reply #9 on: 31 March 2014, 21:37:11 »
MTF Mr B ;D
Not rude or obscure... simply Must Type Faster ;D
Kate
  • Cornwall
    • Drives people mad
« Reply #10 on: 31 March 2014, 21:38:43 »
Yes pics would be really helpful, thanks. :y
« Reply #11 on: 31 March 2014, 21:42:59 »
MTF Mr B ;D
Doh!  ;D ;D ;D (33 secs faster it seems  ;D)
Toledodude1973
  • IPSWICH U.K.
« Reply #12 on: 31 March 2014, 21:52:37 »
i know the ring you mean now thanks, always learning with Omegas :)
« Reply #13 on: 31 March 2014, 23:44:56 »
Was it a recon or 2nd hand abs ecu you fitted Kate?
« Reply #14 on: 31 March 2014, 23:53:21 »
The reluctors - both front & back) are basically the same on her Smart, as they were on my Senators (never ventured under the Merc yet  :o) ) An exception was my C reg MKI Carlton, that used a single sensor that looked at the teeth on diff's crown wheel
Pages: [1] 2 3  All   Go Up
