Author Topic: 2.2 Miss fire  (Read 1722 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
2.2 Miss fire
« on: 01 April 2014, 11:32:32 »
Miss firing under load also of I blip the throttle. Read codes before starting it up and said miss fire cylinder 1. Cleared that one took it around block a few times eml light on read codes again still mids firing and now says miss fire cylinder 4. Have checked coil pack for signs of damage ie burning and I know the plugs are fine as I changed them a couple of months back. I'm confused as to what it could be.
Any help appreciated cheers Ian
Re: 2.2 Miss fire
« Reply #1 on: 01 April 2014, 11:33:56 »
Fresh plugs?
Could well be coil pack breaking down, how old is it/miles?
plym ian
  • Plymouth, Devon
Re: 2.2 Miss fire
« Reply #2 on: 01 April 2014, 11:58:37 »
Fresh plugs?
Changed plugs recently. Pack unknown is there a date stamp on them at all?
Re: 2.2 Miss fire
« Reply #3 on: 01 April 2014, 12:08:59 »
Coil pack idealy needs testing with a test plug with circa 40mm gap.
Any oil in the plug wells?
plym ian
  • Plymouth, Devon
Re: 2.2 Miss fire
« Reply #4 on: 01 April 2014, 12:10:40 »
Tiny bit of oil, but I cleaned them out when I did the plugs. I know cam gasket needs doing.
plym ian
  • Plymouth, Devon
Re: 2.2 Miss fire
« Reply #5 on: 01 April 2014, 12:44:13 »
Just been out again to look at coil pack realised that one of the rubber tubes has split I think when I changed plugs and there's a bit of oil in well which would cause it to short right?.
Just swapped tube for another one that's not damaged took it for a spin and mis fire seams to have gone and no codes. That might have been the problem hopefully  :)
Can you buy the rubber tubes on there own at all?
« Last Edit: 01 April 2014, 12:46:14 by plym ian »
