Author Topic: Rocker cover  (Read 2628 times)
redpaddys11
  • Liverpool
    • 3.2 Elite
Rocker cover
« on: 02 April 2014, 22:32:55 »
Hi everyone. I'm new to this site, and indeed to owning an Omega. I've just recently purchased an '03 3.2 Elite, and there is a very slight smell of burning oil, but no oil under the car, and I was told that the rocker cover gaskets needed replacing on one bank, also the sunroof would only close part way without needing to be reset. I've seen that you should only use VX parts for the gasket, but as I am in no way mechanically minded I have a few questions:
1) Is this a job a very novice mechanic could take on ( and by novice I mean changing a tyre and watching Ed China on Wheeler Dealers!) and apart from a torque wrench what would I need to DIY?
2) If it is a bit too much for me, how much would I be looking at in a garage for this?
3) What is going on with the sunroof needing resetting with a button pressing frenzy like Street Fighter? Am I better off just leaving the thing closed or learning the sequence?
Thanks a lot
martin42
Re: Rocker cover
« Reply #1 on: 02 April 2014, 22:38:23 »
Take a look in the maintenance guides,everything you need to know is there  :y
Re: Rocker cover
« Reply #2 on: 02 April 2014, 22:48:39 »
There are a few members in your neck of the woods who might be able to help :y
Send a PM to Omegod for starters if the guides look too much :y
redpaddys11
  • Liverpool
    • 3.2 Elite
Re: Rocker cover
« Reply #3 on: 02 April 2014, 23:23:08 »
Thanks for that, will try my best to get in touch with them, not the best at computers either ;D!
Re: Rocker cover
« Reply #4 on: 03 April 2014, 07:36:42 »
Although there could be competent garages out there im sure most members on here wouldnt trust them , sure someone will be along to assist you from here  :y
Anyway if your not too confident or have a large swear box  ::) the job can cause more problems if done wrong  :)
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
Re: Rocker cover
« Reply #5 on: 03 April 2014, 23:07:02 »
Read the one about flushing the breathers out. Needs to be done regularly otherwise, well, your rocker-cover gaskets go!
Work is the curse of the drinking classes (Oscar Wilde)
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Rocker cover
« Reply #6 on: 03 April 2014, 23:32:06 »
Can you say HOW regularly, please?
Ron.
Re: Rocker cover
« Reply #7 on: 03 April 2014, 23:39:50 »
Ron.
Every oil change .. which in my case is every 5000 miles .. :)
Bigron
  • Witham, Essex
Re: Rocker cover
« Reply #8 on: 04 April 2014, 01:16:55 »
Oh dear: James did mine a few weeks back when he did my cambelt and thermostat - for the first time since I bought the car, 5 years ago!!!
Ron.
