Author Topic: Standard rear ride height  (Read 5938 times)
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
« on: 03 April 2014, 10:20:11 »
    What is the rear ride height?   Many are talking about it, but try as I may, I cannot find it written down anywhere.   Could somebody point me in the right direction please.   Tha :y nks
Regards
    Dave
Re: Standard rear ride height
« Reply #1 on: 03 April 2014, 10:26:00 »
App. 675mm
DaveA
  • Leicestershire
« Reply #2 on: 03 April 2014, 10:29:33 »
   Thanks Rob :y
Regards
    Dave
steve6367
« Reply #3 on: 03 April 2014, 11:30:35 »
App. 675mm
Where is that measured to Rob?
amba
  • Medway towns
    • German V6
« Reply #4 on: 03 April 2014, 12:12:53 »
From ground through center of wheel to underside of wheel arch :y
steve6367
« Reply #5 on: 03 April 2014, 19:52:39 »
Ummm....the new (to me) 2.5 saloon is 720mm passenger side and 730 drivers side.....
Is that bad? Seems way out based on the above.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #6 on: 03 April 2014, 19:57:30 »
Just let some air out both drivers side tyres. Sorted  :y
« Reply #7 on: 03 April 2014, 20:01:05 »
Does it have self leveling suspension ?? if so it "may" be stuck in the raised position ...
steve6367
« Reply #8 on: 03 April 2014, 20:11:41 »
No it's only a CD spec so just standard setup.
The Estate seems to be 700mm & 710mm...
Steve
powerslinky
« Reply #9 on: 03 April 2014, 20:44:22 »
Possibly incorrect springs . .  as said, in above post,  should be circa 675mm    + or  - 5mm  IMO  :-\
steve6367
« Reply #10 on: 03 April 2014, 20:58:56 »
Same for the Estate or is that supposed to be higher?
steve6367
« Reply #11 on: 03 April 2014, 21:00:17 »
Should I be changing them? Will it cause issues?
powerslinky
« Reply #12 on: 03 April 2014, 21:14:18 »
Handling will suffer quite badly I would think :-\
 Have a good look around the springs themselves , there may be a 2 letter code painted on them  ( for example LC  or LA  or similar)
Not sure what the code for std springs is or if std actually have a code .Also what year is the car ?
Mr. Gixer will be along soon , he knows all about this in detail  ;) & will probably advise you on what to change to if needed
But STD ride height should be 675mm
steve6367
« Reply #13 on: 03 April 2014, 21:53:18 »
It's a 2000 and a quick glance in the dark the springs looks too new to be original I would say, still nice black paint. Although can't see any record of them being changed in the history I have.
« Last Edit: 03 April 2014, 21:57:50 by steve6367 »
powerslinky
« Reply #14 on: 03 April 2014, 22:05:13 »
Just out of interest . . does the car have a tow bar fitted ?
