Author Topic: Misty/cloudy MV6 headlights.  (Read 6116 times)
Keith ABS
  • Maldon Essex
Re: Misty/cloudy MV6 headlights.
« Reply #15 on: 10 April 2014, 19:36:47 »
  G3 compound available from car paint suppliers (not halfords!!!) I got the U pol equivalent of Farecla for around £6 for the tube
Keith B
« Reply #16 on: 10 April 2014, 19:55:51 »
if you want a quick result which wont be shorter than a few hours in total  ;D  you have to use 1500 grid wet sanding and than a orbital polisher with farecla g3..  polishing by hand will be too long.. I'm afraid..
I might be wrong, but I've got a feeling that they might have taken that into consideration when designing the kit...
some chemicals work wonders some not, just a hoax( and lots of them) .. so I cant comment as I didnt use that product..
however, the codition of headlights and how deep the damage decides the total work time.. but even cleaning the mess that paste creates takes half an hour ;D
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #17 on: 10 April 2014, 22:24:33 »
however, the condition of headlights and how deep the damage decides the total work time.. but even cleaning the mess that paste creates takes half an hour ;D
How many gallons of the stuff are you using? It's only a small area, and easily done by hand. 10 minutes to get a nice clear lens, and 30 seconds to wipe off the surplus. That's another reason not to use a mop, as that does fling compound everywhere.
« Reply #18 on: 10 April 2014, 22:27:41 »
your headlights probably not much damaged :)
« Reply #19 on: 11 April 2014, 10:57:30 »
As i recall, pre polishing, Nicks car looked almost French ;D
  • Chatham, Kent
« Reply #20 on: 11 April 2014, 11:16:57 »
Omega lights by Cibie ;D
They were rough enough that you could probably have used them as an emery board too.
I''ve cleaned several other plastic lenses, and never had any problem with G3 by hand. It's quick, easy and effective. As I have repeatedly posted, it's only worth buying the specific kits if you have nothing that will do the job.
« Reply #21 on: 11 April 2014, 18:27:07 »
Vim?  :-\
 :D
You never know , give it a try on a bit  :-\
« Reply #22 on: 11 April 2014, 19:44:26 »
I've managed to get them half decent by using a brillo pad followed by two or three applications of T-Cut.
They shouldn't be a problem at the MOT now. :y
« Reply #23 on: 11 April 2014, 20:00:58 »
Needs must mr opti  :D now whats mrs opti going to do the dishes with  :-\
« Reply #24 on: 11 April 2014, 20:09:56 »
When I say 'brillo pad'  what I actually  mean is 'Sainsbury's VALUE soap filled pad'.... ;D
Times are hard, Mr Emd, and the taxman makes the terminator look like Mary Poppins. ::) ::) :)
« Reply #25 on: 11 April 2014, 20:13:07 »
The Omega will save you a bob or two on your fuel bill now you have 2 pots less  :y
Page created in 0.153 seconds with 20 queries.
