Author Topic: Misty/cloudy MV6 headlights.  (Read 6114 times)
« on: 10 April 2014, 10:42:17 »
Does anyone have an inexpensive tip for bringing the headlights of my MV6 back to their former glory?
The MOT is due in June and the lights have taken on a dull opaque appearance of late. :-\
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Misty/cloudy MV6 headlights.
« Reply #1 on: 10 April 2014, 10:47:20 »
im sure theres a how to on this opti.  :y
http://www.omegaowners.com/forum/index.php?topic=90643.0
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 10 April 2014, 10:50:45 »
Some kits on ebay / amazon that do the job.
http://www.amazon.co.uk/Headlight-Tail-Light-Restoration-kit/dp/B002FUOFOK/ref=sr_1_7?ie=UTF8&qid=1397123353&sr=8-7&keywords=headlight+restoration+kit
Needs plenty of elbow grease or a battery drill though  ;)
If they are not too bad, t cut or any cutting compound like G3 will improve them  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 10 April 2014, 11:20:45 »
Any mild abrasive cream/paste will do the job. If you already have such a thing then you'll get the job done in the time it takes to have a coffee.
T-cut is probably too mild, which just means more effort.
A few minutes with some G3 easily restored my yellow and rough lights
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #4 on: 10 April 2014, 12:03:16 »
Just done one of two on my MV6 and as said abrasive cream, but it took longer than one coffee. I got some from e-gay but you could use any. They come up OK, but don't look new. They will pass an MoT OK IMO  :y :y
Stemo
« Reply #5 on: 10 April 2014, 12:28:19 »
Here we go. One thread 'Back on the road', next thread 'How much will this cost?'  ;D
And an MOT to follow. Cut your losses Mr. O.  Would £300 buy it? ;)
Keith ABS
  • Maldon Essex
« Reply #6 on: 10 April 2014, 12:53:54 »
Flat down the lenses with 1200 grit then superfine(2000 grit)  After the panic has gone at how they look, polish with G3 compound.  Brings them back to near new look.
Keith B
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #7 on: 10 April 2014, 13:37:54 »
PM with your requests.
« Reply #8 on: 10 April 2014, 16:09:35 »
G3 paste seems to be consistently mentioned. Where can I get this from?
The Meguiar's 'headlamp correction kit' also looks interesting. :y
I've only used T-Cut/Colour Cut so far, but as mentioned, it doesn't seem quite abrasive enough to make much difference.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #9 on: 10 April 2014, 16:15:02 »
3M headlight restoration kit  :y
« Reply #10 on: 10 April 2014, 17:22:50 »
if you want a quick result which wont be shorter than a few hours in total  ;D  you have to use 1500 grid wet sanding and than a orbital polisher with farecla g3..  polishing by hand will be too long.. I'm afraid..
humbucker
  • Cambridgeshire
« Reply #11 on: 10 April 2014, 17:29:44 »
I might be wrong, but I've got a feeling that they might have taken that into consideration when designing the kit...
« Reply #12 on: 10 April 2014, 17:56:32 »
Vim?  :-\
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #13 on: 10 April 2014, 18:16:40 »
G6 rapid on a power polisher is better than G3, less messy & only took me about 15-20 mins to do both sides  :y
Stemo
« Reply #14 on: 10 April 2014, 18:25:41 »
.......mind you, my lenses are only 1mm thick now. ;D
Page created in 0.043 seconds with 16 queries.
