Author Topic: Metal Sunroof Trim  (Read 2965 times)
amba
  • Medway towns
    • German V6
Metal Sunroof Trim
« on: 10 April 2014, 22:25:47 »
Expect I am not alone here so would welcome others solutions to the flaky paintwork on the metal sunroof trim.
Can the trim be removed on its own to refurbish or is it a mask up/rub down/prime/paint ?
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Metal Sunroof Trim
« Reply #1 on: 10 April 2014, 22:33:09 »
Used the pressure washer yesterday.. Got a little close trying to get the green stuff away and well... It stripped some of the touch up paint I put there last year  ;D .. No worries put some more touch up paint today, Not noticeable again unless you really looking.  :y
amba
  • Medway towns
    • German V6
« Reply #2 on: 10 April 2014, 22:36:52 »
Not sure if mine is due to pressure washer as seems to be more white /grey metal visible than original black. :o
« Reply #3 on: 10 April 2014, 22:39:07 »
You'll be masking off & respraying because it's all one unit.
If you do a search, MarksDTM showed what screws need to be undone to remove the glass - there's only 6 IIRC
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #4 on: 10 April 2014, 22:43:51 »
Was considering last year to remove all the paint and polish the alloy up, Thought it'd look good especially on a darker coloured Omega..
amba
  • Medway towns
    • German V6
« Reply #5 on: 10 April 2014, 22:46:40 »
Found the guide for removal,so looks like it will be comimg out.
What is the best way and product needed to repaint the metal as assume its alloy
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #6 on: 10 April 2014, 22:54:09 »
Had the same problem with mine. Its an aluminium alloy
Rubbed it down with an abrasive strip (used for cleaning copper pipe in plumbing) and brush painted with hammerite (3 coates).
This was the result 2 years ago and it still looks the same
Wear a glove when rubbing down takes a lot of effort and my thumb took about 2 weeks to heal
BTW did it in-situ
This is the abrasive strip
« Last Edit: 10 April 2014, 22:55:51 by SIR Philbutt »
amba
  • Medway towns
    • German V6
« Reply #7 on: 10 April 2014, 22:58:43 »
Cheers for advise SIR Philbutt.
Your efforts and final result looks good and I will be happy if mine comes close to that as looks more white/grey than black at present.
Assume you removed the entire glass as per guide ?....Smooth Hammerite ??
SIR Philbutt
    • PJB Home Services
« Reply #8 on: 10 April 2014, 23:03:00 »
No did in-situ. Put duct (or duck) tape around on paint and glass to stop scratching, Yes used smooth.
I think the bubbling and grey/white appearance is due to some kind of oxidation going on, water ingress maybe
« Reply #9 on: 11 April 2014, 16:58:51 »
Hammerite smooth  :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #10 on: 11 April 2014, 18:27:27 »
What's a sunroof. ;D
Hoof'land storeman.
« Reply #11 on: 11 April 2014, 18:28:48 »
That glass thing in the roof that opens when it likes  ::) :P
biggriffin
« Reply #12 on: 11 April 2014, 18:39:42 »
Superior cars didn't have them...welll none of my omegas have :)
Hoof'land storeman.
symes
  • oxford
    • R reg 940 volvo
« Reply #13 on: 12 April 2014, 10:37:43 »
when i do mine-will do it same color as body-just to be different
amba
  • Medway towns
    • German V6
« Reply #14 on: 12 April 2014, 12:31:35 »
Thanks for advise,guys,
Smooth black hammerite paint/couple of strips of various grades of emery paper/masking tape and I am now good to go. :y
