Author Topic: Ford focus 1.6 2005  (Read 2107 times)
rikki_essex
  • essex
    • 2L gls estate with lpg 20
Ford focus 1.6 2005
« on: 11 April 2014, 13:55:56 »
Good afternoon all, could I trouble you with a problem on my mums car no one can seem to diagnose and sort out the problem. I done the self test on the dash board and it came up as er0608 that is saying the speed sensor so I done a bit of reading and took some advice to get it change. So she booked it in to the garage she uses and after having it for a day the phone and said they hadn't changed it as they don't think that's the problem so they said they took it out cleaned it and put it back. She drove it away from the garage and 2 minutes down the road it done the same thing. It's been losing power and cutting out so she phoned the garage back and booked it back in for the next day but after being there the whole day they phoned to say I was another problem and supplied her with the code e00001 and gave her the number to an auto electrician and said to contact them. Any one got any ideas. Thanks in advance Rikki
regards Rik
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Ford focus 1.6 2005
« Reply #1 on: 11 April 2014, 14:15:23 »
Knowing what the car is or isn't doing would help aswell.
 eg missfire,etc the problem. :)
Hoof'land storeman.
« Reply #2 on: 11 April 2014, 16:33:33 »
Engine speed sensor is a crank sensor which also ties in with the symptoms, you need a different garage
