Author Topic: omega mechanics needed  (Read 1433 times)
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« on: 13 April 2014, 19:26:11 »
An appeal to DLK OR EP, are either of you availible on the 19th april to replace the cam covers and coil pack, leads and poss re seal the oil cooler plate on my V6, as james is on nights and cant make it.
I have the cam cover gaskets and coil pack and leads, and oil pipe sealing rings(metal), new oil cooler hollow bolts. plan to re use the existing oil cooler as it is the upgraded ss type and no issues, just a poss leaking plate.
Can travel to you if needed. :-*
Jaguar XJ6
Re: omega mechanics needed
« Reply #1 on: 13 April 2014, 21:57:01 »
I'm away Gary, sorry :(
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #2 on: 13 April 2014, 22:39:34 »
could poss help you out, chances are the oil cooler may be ok, just the leaking cam covers?
im up in burton on trent though, will check with the powers that be 1st to make sure were not out that day.  :y
jon.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 14 April 2014, 06:58:53 »
Give serek a pm. He might be able to fit you in. And there's a few shops near for tother half if needed :y
Hoof'land storeman.
