Author Topic: vec b dti - snapped spring q  (Read 1676 times)
mcd840
  • Alloa
    • vectra cdx
« on: 14 April 2014, 18:35:07 »
hi, as above. the small end piece of the front pass side spring has snapped off from the bottom, the spring still sits securely in the seat, im just wondering if this will be a fail come mot time or just an advisory ?
cheers
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: vec b dti - snapped spring q
« Reply #1 on: 14 April 2014, 19:24:06 »
Yep :y fail if they find it
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
« Reply #2 on: 14 April 2014, 19:31:57 »
Same thing on my mig mate. Mot spotted motor and dropped slightly on Nsr then he carried out mirror inspection. Failed :'(
mcd840
  • Alloa
    • vectra cdx
« Reply #3 on: 15 April 2014, 17:59:08 »
oh well new set front springs it is then. also need to replace the inner drive shaft boot as its split. can i ask does removing the struts also affect allignment, seems to be alot of debate on this, some say no it doesnt, others like the guy that done my hunter 4 wheel allighnment says the allignment should be checked after doing anything with the susspension from replacing bushes etc.
cheers
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #4 on: 16 April 2014, 00:56:10 »
Just answered that yourself :y
mcd840
  • Alloa
    • vectra cdx
« Reply #5 on: 16 April 2014, 19:49:42 »
which is it though ?  ;D
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #6 on: 16 April 2014, 19:55:01 »
Mainly the camber on the Vec B...
I have a pair of front springs here fora Vec B, but theyre for a V6, the dervs use the same springs as the V6's IIRC... You can have them for nowt if you want to come and collect them from Wigan....
D.I.L.L.I.G.A.F...
mcd840
  • Alloa
    • vectra cdx
« Reply #7 on: 16 April 2014, 20:01:15 »
thats very kind of you mate, a shame you werent closer !
