Author Topic: What shall I do with my 2.2?  (Read 3918 times)
« on: 17 April 2014, 16:48:43 »
I have a late 53 plate 2.2 petrol CD with 96k miles.
I parked it up and sorned it because it had early symptoms of HG failure.
This car has LPG - a nice stag 4Eco kit with 100l tank and is MOT until November
Since I laid it up 3 or 4 months ago, I've not even started it, instead driving my 3.0 project, which is a roadworthy work in progress!
I WILL be fixing the HG as its a cheap / easy / quick ish repair and nothing more than a paperweight without!
The options as I see them:
1) fix at my leisure and clean up. We are doing a 3 week long road trip to Spain in sept and the gas would be a financial godsend
2) fix and remove the LPG. Sell as standard car. Use LPG parts to convert the 3.0
3) sell complete with LPG. May not increase value much though as not yet certified / on database.
No rush, just wondering what you'd do? :y
Re: What shall I do with my 2.2?
« Reply #1 on: 17 April 2014, 17:00:09 »
Fix it up and keep it, the LPG parts, very little will fit the 3.0
The ECU won't work, the injectors, not enough, not really good idea mixing.
Vap won't be up to the job, also is tank multi-hole? Doubt it for 4 pot. So not really worth moving parts.
Pence per mile on my 2.2 is ~12p, so effective 50mpg easy all day long  :y
« Reply #2 on: 17 April 2014, 17:01:19 »
Option 1 then when you get back from your hols Option 3!  :y
« Reply #3 on: 17 April 2014, 17:04:04 »
Thing is, I much prefer my 3.0. My commute after June will be 7 miles so fuel not an issue.
Tank is 4 hole, so £300 alone in rear end kit. I could potentially buy another stag 4 kit and run one kit per bank on the v6 :y
« Reply #4 on: 17 April 2014, 17:17:44 »
If you fix up the Desmond for your holiday and then sell it when you get back, wouldn't that fund the kit for your V6?  :-\
« Reply #5 on: 17 April 2014, 17:20:14 »
Be interesting running 2x Stag 4pot kits on a 6pot engine? Won't the software not like running each kit on 3?
« Reply #6 on: 17 April 2014, 17:22:44 »
The software is stupid, the gas ecu's wouldn't know each other we're there :)
All the gas ecu does is copy a signal and fire a gas injector :y
Taxi_Driver
« Reply #7 on: 17 April 2014, 18:53:41 »
option 3 is the way to go  :y
If i can sell a 2.2 lpg'd omega with 150k on its clock with multiple issues, ie abs not working/more exhaust bandage than exhaust/more rad weld than water/warning light on for low coolant...just to name a few probs.....for £1500, ok then it was about 7 years old.....but he was determined to buy it ....as it was lpg'd  :y
« Reply #8 on: 17 April 2014, 23:06:03 »
I can't believe you've admitted using Radweld in an Omega on here!!!  :o  ;D
« Reply #9 on: 17 April 2014, 23:08:58 »
Option 1, then flog it :y
Taxi_Driver
« Reply #10 on: 18 April 2014, 08:06:43 »
When your rad is like a colander.....and its only about £2 ish in halfords with trade card....its cheaper than a new rad  :y ;D
« Reply #11 on: 18 April 2014, 11:01:07 »
Right upto the point that the heater matrix needs replacing and the car is impossible to drive in winter ::)
Taxi_Driver
« Reply #12 on: 18 April 2014, 18:49:46 »
Ask me if i would add radweld to a keeper, then the answer would be no, but as the car only had months to be useful me.....would you goto the expense of a new rad?
« Reply #13 on: 18 April 2014, 22:10:35 »
Tough call that :-\ depends I guess on what was happening to the car afterwards...
Taxi_Driver
« Reply #14 on: 19 April 2014, 18:23:34 »
Well, as i dont have it anymore.....sold....on an autotrader ad  :y
