Author Topic: Focus 1.4 Timing belt  (Read 1381 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 18 April 2014, 12:39:01 »
Son has just bought a '52 plate for £390 with 104K, and I suspect it has never had the belt done. Any particular problems with doing the belt? Also am I correct that it will be OBD11?
martin42
Re: Focus 1.4 Timing belt
« Reply #1 on: 18 April 2014, 12:44:58 »
Cambelt is easy,just need cam looking kit and crank locking pin,gates kits are ford oe,need cam cover gasket aswell,might be worth changing water pump at same time.
Shackeng
  • Ramsbury
« Reply #2 on: 18 April 2014, 13:00:29 »
 :y :y :y
Omegatoy
  • UK
« Reply #3 on: 18 April 2014, 20:29:56 »
lol easy if the crankbolt comes out ok!! last one i did had to go and borrow a truck airgun with 3/4 drive,disconnect the safty on the compressor wind it right up, then let it fly, it just moved it! this was after spending couple hours failing with a breaker bar, then with a halfinch windy gun!
