Author Topic: Scuttle Panel Sealent Mod - How To?  (Read 1899 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« on: 18 April 2014, 16:09:35 »
Having to replace my coilpacks again due to the usual water running through the scuttle and onto them causing them to rust and burst and further still the spark plugs rusting, has anyone done this mod to the scuttle panel to stop the water getting through?
I'm curious where exactly it is I should be applying sealants to correct this problem...
tidla
  • solihull
Re: Scuttle Panel Sealent Mod - How To?
« Reply #1 on: 18 April 2014, 17:19:09 »
around the wiper spindles.
« Reply #2 on: 18 April 2014, 17:32:45 »
And where the two scuttle parts meet and along the front edge where they sit on the flat surface :y
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #3 on: 18 April 2014, 17:36:41 »
Is there a recommended sealant, please?
Ron.
tidla
  • solihull
« Reply #4 on: 18 April 2014, 17:45:29 »
cheapest black window frame or similar. scuttle will have to come apart for hbv, breathers, coil pack, abs, oil cooler....
Bigron
  • Witham, Essex
« Reply #5 on: 18 April 2014, 18:15:11 »
Thanks, tidla. As far as I know, I don't have a specific problem, I was just interested in the topic for preventive maintenance, so I don't need to do large amounts of dismantling, do I?
Ron.
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #6 on: 18 April 2014, 20:12:43 »
Easy job Ron, once you've got the sealant :y
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
chrisgixer
« Reply #7 on: 19 April 2014, 03:13:22 »
Wiper spindle above pot 5 and the the metal edge of the scuttle drain, where vx have put a strip of draft excluder foam ::) ...are the usual culprits.
Also check the windscreen seal to scuttle is still firmly clipped onto the bottom edge of the screen.
In fact if you get a hose or watering can and poor water on the screen, you'll see where the water is going. Although you'll need it dry for the sealant to work obviously, and cover the back of the engine to keep the water off if the cp's have been changed.
I used cam cover goo, as that's all I had. But any bathroom sealant or gutter seal will do, ..... preferably black. ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #8 on: 19 April 2014, 21:46:21 »
I made a cover that bolts to the plenum and covers the packs like a roof, doesn't look great but does the job. :)
Hoof'land storeman.
