Pages: 1 [2] 3  All   Go Down
Author Topic: Squealing Front Brakes, Anyone Tried This Stuff ?  (Read 6151 times)
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Squealing Front Brakes, Anyone Tried This Stuff ?
« Reply #15 on: 20 April 2014, 07:19:13 »
My understanding is that the base is a high temperature grease - needed for brake pads - loaded with copper particles to aid heat dissipation/transference. Just to sing its praises even more, it's great for other areas where heat is an issue and you might want to disassemble again sometime: exhaust bolts, spark plugs, manifold bolts, etc.
Ron.
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #16 on: 20 April 2014, 20:35:02 »
On My BMW 320i for the past 4 1/2 years I always used ATE Plastilube silicone grease on the back of the pads and sliders. It stopped all the sequels dead in there tracks and I've never had a problem since.
I don't know if this is totally correct but my understanding is that if you get cooper grease onto your seals it will parish them over time. That is why I went over to ATE Plastilube in the first place.
Hope this helps.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #17 on: 20 April 2014, 20:47:44 »
Thanks for the info and advice chaps  :y
I'll try the Copper slip firstly, Failing that new pads it is with copper slip, Seen some mintex for £18.46 delivered  :y
« Reply #18 on: 20 April 2014, 22:12:43 »
GM front pads on TC around £15 Jay :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #19 on: 20 April 2014, 22:16:41 »
Don't have TC mate, Will inquire how much they are from VX if needed mind  :y
chrisgixer
« Reply #20 on: 20 April 2014, 22:23:24 »
How/why does any member not acquire tc access?
On one hand there's moaning about parts prices, on the other there's a refusal to use genuine parts. Because of prices. I don't get it.
Abs tc card costs 20/25(?) quid. You'll save more than the £20 on a 5 litr can of oil. Especially in conjunction with the 20lt 3 for 1 offer.
« Reply #21 on: 20 April 2014, 22:38:49 »
Sorry Jay, forgot no TC dealers near you ;)
« Reply #22 on: 21 April 2014, 00:04:37 »
£15 on TC equates to about £25 without ::) hardly ground breaking...
chrisgixer
« Reply #25 on: 21 April 2014, 01:42:35 »
Not really, as they won't fit.... unless that's a generic pic?
« Reply #26 on: 21 April 2014, 01:45:48 »
Yep they're for a 4 pot, no good for a V6 ;)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #27 on: 21 April 2014, 02:31:18 »
Copy & Past
Engine Size: 2.0 - 2.0 16V -2.5 V6- 2.5TD - 3.0 V6
« Reply #28 on: 21 April 2014, 12:43:06 »
Those listed are upto Chassis number V199999, and for cars fitted with ATE calipers...
Later cars have Lucas calipers, which take a different shaped pad :y
That link is a generic image, but basically, ATE pads are kind of bat shaped, Lucas pads don't have any 'wings'...
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #29 on: 21 April 2014, 14:11:13 »
...And clean your slide pins of crap and paint some silicone paste on them in addition to your copper greasing the pads  :y
RIP Paul Lovejoy
Pages: 1 [2] 3  All   Go Up
