Pages: [1] 2 3  All   Go Down
Author Topic: Squealing Front Brakes, Anyone Tried This Stuff ?  (Read 6155 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« on: 19 April 2014, 19:54:15 »
They occasionally squeal under light braking, Discs/Pads are 10 months old with plenty of meat on them...
Has anyone tried this stuff ? LINK
tidla
  • solihull
Re: Squealing Front Brakes, Anyone Tried This Stuff ?
« Reply #1 on: 19 April 2014, 20:17:43 »
Might as well put the money toward some quality brake pads.
« Reply #2 on: 19 April 2014, 20:25:11 »
And copper slip ::)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #3 on: 19 April 2014, 21:55:17 »
There are cheaper alternatives to that Wurth branded one...But i see what you mean.. I don't fancy changing the pads, Unless someone can recommend some pads no more than £40 say  :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 19 April 2014, 21:56:30 »
Wow, that stuff is expensive!
Especially when a decent clean of the caliper and hub with squirt of brake cleaner, a scraper and wire brush, followed by a smear of copperslip on the back of the pad will do just as good a job. And you can use the copperslip elsewhere.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #5 on: 19 April 2014, 21:57:31 »
And copper slip ::)
Behind the pads aye, Don't think I've got any copper slip left.. Any particular brand ?
  • Chatham, Kent
« Reply #6 on: 19 April 2014, 22:09:39 »
The universe will end in a puff of smoke if you don't buy genuine Vauxhall.
Seriously, like most lubricants, it really doesn't matter!
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 19 April 2014, 22:10:50 »
any copperslip will do, just go to Halfords buy a BIg tin and a 1" paint brush, keep it handy allways handy to have about :)  :y
Hoof'land storeman.
biggriffin
« Reply #8 on: 19 April 2014, 22:11:54 »
The universe will end in a puff of smoke if you don't buy genuine !
sarcasm. I like ;D
Hoof'land storeman.
  • Chatham, Kent
« Reply #9 on: 19 April 2014, 22:16:12 »
I was trying for satire, but will happily settle for sarcasm ::)
biggriffin
« Reply #10 on: 19 April 2014, 22:20:23 »
Carefull the genuine police will be along soon on there bikes ;D
Hoof'land storeman.
« Reply #11 on: 19 April 2014, 22:45:07 »
Aquire the above, pads out, do what Nick said and refit... ::)
« Reply #12 on: 19 April 2014, 23:14:16 »
Why/how does copper slip on the back of the pads stop them from squealing?  :-\
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #13 on: 19 April 2014, 23:17:39 »
No idea  ;D
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #14 on: 20 April 2014, 00:42:53 »
My understanding is that copper slip reduces the squeal caused by slight moment of the pad under braking, often referred to as rattle - hence the term anti rattle shims that are often found on certain makes of pads. Sometimes, instead of shims, pad manufacturers use an anti squeal compound on the back of the pad, which looks like a crinkly substance. In this case, there is no real need to use copper slip, although I always use a minute amount as good measure. On the rear of VX replacement pads you may have noticed that only two pads have a riveted anti squeal shim on the back - this should go on the piston side with a smear of copper slip for good measure. Basically, copper slip does the same job as the anti squeal shims  or the anti rattle compound on the back of the pad.
Pages: [1] 2 3  All   Go Up
