Will these fit the FL Omega
Started by Mr.OmegaMan, 26 April 2014, 07:54:39
Mr.OmegaMan
Also would these rattle more I wonder or cure the common rattle the originals make... Mine are quiet currently unless driving on moderately/very rough surface roads thanks to silicone spray months ago, Just thought these would look good.. Anyone tried these or similar ?
http://www.ebay.co.uk/itm/230784866226
Are you related to Stemo ::)
Those will rattle even more ;D
Try this...
Remove the pins by carefully prying the orange/red tab out, then simply lift off. Wrap two turns of insulation tape around the base of the pin so that the top edge of the tape is level with the bottom of the tab. Refit the tab then push the button back onto the lock rod until it clicks.
Rattle stopped :y
Would normally be free, but for you, a one time offer or £49.99 ;D
Stemo
Quote from: Taxi Al on 26 April 2014, 10:11:20
Try this...
Rattle stopped :y
Not many cars have door pins now, surely? 1980's retro or what?
ronnyd
Just slid small black cable ties down beside mine, you can,t see em and they don,t rattle. Bit of a bodge but''''' :D
Had some of those on old v6 vectra , a nice upgrade  :y
