Author Topic: Guess the plug (part 1)  (Read 10527 times)
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« on: 26 April 2014, 18:34:28 »
3.2 MV6 Auto
Can anyone tell me what the lower plug wrapped in protective cardboard is in this pic? Thanks.  :y
PM with your requests.
Re: Guess the plug (part 1)
« Reply #1 on: 26 April 2014, 18:48:15 »
Remove the cardboard to give us a clue Dan :)
humbucker
  • Cambridgeshire
« Reply #2 on: 26 April 2014, 18:53:54 »
Hehe, will do, didn't know if it was a common sight?! I'll grab another pic asap.
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #3 on: 26 April 2014, 19:26:23 »
I found one on my car too and posted about it but don't think anyone knew what it was either. was yours tucked behind central locking ecu as well?
2woody
  • Northumberland
« Reply #4 on: 26 April 2014, 22:23:46 »
now-redundant plug for the dim-dip control unit I think
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #5 on: 26 April 2014, 22:31:06 »
If its redundant why is it still there?
« Reply #6 on: 26 April 2014, 22:34:38 »
Cheaper to keep it in the loom & not use it than remake the loom without it  ........... 'dim dip' isn't fitted to anything anymore.
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #7 on: 26 April 2014, 22:36:05 »
at least it gives people a power source for handsfree and the like
humbucker
  • Cambridgeshire
« Reply #8 on: 26 April 2014, 23:16:32 »
Stupid question, but what's dim dip?  :-X
« Reply #9 on: 27 April 2014, 05:17:08 »
Twin filament headlight bulbs... Fitted to any thing without separate main beam :y
An obvious modern example would be a Ford Transit. The controller is there to prevent the dipped and main beam circuits from operating simultaneously :y
« Reply #10 on: 27 April 2014, 06:48:02 »
No it's not.  ::)  ::)
Dim/dip was fitted for only a short time ... SWMBO M reg Hyundai had it. It was to stop people driving on just side lights, when you had the ignition on & side lights, you got your dipped beam on too but at lower power via another box of electrickery.  :y
http://en.wikipedia.org/wiki/Daytime_running_lamp
United Kingdom[edit]
UK regulations briefly required vehicles first used on or after 1 April 1987 to be equipped with a dim-dip device[20] or functionally dedicated daytime running lamps, except those vehicles type-approved to ECE Regulation 48 regarding installation of lighting equipment—this exception was made because ECE R48 did not require dim-dip or daytime running lights, and while countries signatory to the ECE Regulations are permitted to maintain their own national regulations as an option to the ECE regulations, they are not permitted to bar vehicles approved under the ECE regulations. The dim-dip system operated the low beam headlamps (called "dipped beam" in the UK) at between 10% and 20% of normal low-beam intensity. The running lamps permitted as an alternative to dim-dip were required to emit at least 200 candela straight ahead, and no more than 800 candela in any direction. In practice, most vehicles were equipped with the dim-dip option rather than the running lamps.[20]
The dim-dip lights were not intended for use as daytime running lights. Rather, they operated when the engine was running and the driver switched on the front position (parking) lamps. Dim-dip was intended to provide a nighttime "town beam" with intensity between that of the parking lamps commonly used at the time by British drivers in city traffic after dark, and low beam headlamps; the former were considered insufficiently intense to provide improved conspicuity in conditions requiring it, while the latter were considered too glaring for safe use in built-up areas. The UK was the only country to require such dim-dip systems, though vehicles so equipped were sold in other Commonwealth countries with left-hand traffic.[21]
In 1988, the European Commission successfully prosecuted the UK government in the European Court of Justice, arguing that the UK requirement for dim-dip was illegal under EC directives prohibiting member states from enacting vehicle lighting requirements not contained in pan-European EC directives. As a result, the UK requirement for dim-dip was quashed.[20] Nevertheless, dim-dip systems remain permitted, and while such systems are not presently as common as they once were, dim-dip functionality was fitted on many new cars well into the 1990s.[citation needed]
« Last Edit: 27 April 2014, 06:50:03 by Andy B »
martin42
« Reply #11 on: 27 April 2014, 07:38:07 »
My 97 escort has it aswell  :y
« Reply #12 on: 27 April 2014, 09:15:29 »
I thought it was a good idea . .
martin42
« Reply #13 on: 27 April 2014, 11:56:41 »
It sure is  :y
« Reply #14 on: 27 April 2014, 12:47:06 »
Never owned a car with that arrangement... if it's dark, I always put my headlights on ::) so summat new learnt :y
