Author Topic: Peugeot 206 2.0l clutch replacement  (Read 6552 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 26 April 2014, 21:05:37 »
Hi guys,
Wifey needs a new clutch. I've determined this because she has severe clutch judder and clutch pedal is really high. Is this enough diagnosis?
Anyway when replacing the clutch I'm looking for some online advice if possible as I've only ever done one clutch on a fiesta previously.
Is there anything to the procedure other than removing and marking shift linkage,driveshafts pulled out, removing pass. Side engine mount and supporting sump with wood and floor jack, removing any other stuff connected and then removing bell housing bolts?
Is the release bearing the same as on the ford I.e. All one piece that I just replace whilst gearbox is off?
Any info you could throw my way would be wonder bra  :y
Thanks.
RIP Paul Lovejoy
serek
  • huntingdon
    • 3.2 mv6
Re: Peugeot 206 2.0l clutch replacement
« Reply #1 on: 26 April 2014, 21:14:19 »
very easy job, same like fiesta
get gearbox oil seals as they leak  :y
Webby the Bear
  • Northampton
« Reply #2 on: 26 April 2014, 21:17:10 »
Thanks mate. The seals being the ones where the drive shafts go in to?
RIP Paul Lovejoy
serek
  • huntingdon
    • 3.2 mv6
« Reply #3 on: 26 April 2014, 21:18:08 »
yes them, you can get those from any parts supplier
they about £12pair
Webby the Bear
  • Northampton
« Reply #4 on: 26 April 2014, 21:20:08 »
Thanks mate  :y
Is the clutch a cable?
RIP Paul Lovejoy
serek
  • huntingdon
    • 3.2 mv6
« Reply #5 on: 26 April 2014, 22:29:02 »
Thanks mate  :y
there 2 different set ups on those
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 27 April 2014, 00:12:56 »
2.0lt,petrol or diesel Webby  ???
other rides
« Reply #7 on: 27 April 2014, 10:07:52 »
The 406 has a pig of a centre bearing on the os driveshaft!
Webby the Bear
  • Northampton
« Reply #8 on: 27 April 2014, 12:19:33 »
Sorry Henryd..... 2.0l petrol :)
Any more tips folk can give me?
RIP Paul Lovejoy
r1
  • nottingham
« Reply #9 on: 01 May 2014, 17:46:20 »
[/quote]
get someone else to do it!
henryd
  • west cornwall
« Reply #10 on: 01 May 2014, 18:42:20 »
206 is same,I've done a few 2.0 Hdi clutches on the 206's and they aren't too bad to be honest,once you get rid of the airbox and battery and tray its quite accessible
other rides
Webby the Bear
  • Northampton
« Reply #11 on: 02 May 2014, 17:55:15 »
When you say centre bearing do you mean the part on the longest drive shaft where you have like a half moon shell type thing and you remove that and then remove drive shafts? Why would that be difficult to remove as it's only two bolts.  :-\ Or have I got it wrong  ::) ;D
RIP Paul Lovejoy
henryd
  • west cornwall
« Reply #12 on: 06 May 2014, 13:51:21 »
It is two bolts with offset heads so you loosen the nuts about half an inch then push the bolts  back and turn them 180 degrees,you can then knock the support bearing and shaft out of the mounting,the bearing can be F tight in the housing though :-\
other rides
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #13 on: 06 May 2014, 20:22:01 »
I remember having a hell of a job getting the bottom balljoint back into the hub on one of these, turned into an epic battle involving planks of wood  ;D
