Author Topic: WTD Self Levelling Plumbing  (Read 4915 times)
« on: 30 April 2014, 20:44:40 »
As above, specifically the drivers side shock connector section, about 8" long, goes to another connector just inside the chassis rail :y
Only need one O ring from it, but if that pipe is available then it minimises any transit damage to the O ring.
Am assuming that saloon and estate are the same :y
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: WTD Self Levelling Plumbing
« Reply #1 on: 02 May 2014, 18:13:45 »
Is it just the small orange o ring you are after. I have one here if that is all you need.
Al
If it aint broken, you aint trying hard enough
« Reply #2 on: 02 May 2014, 22:14:24 »
Not sure tbh, I think the drivers side had two... Nearside only has half of one, and the squished half wt that ;D
Ideally need that complete pipe trom shock to T piece :y
al brown
  • alton, hants
« Reply #3 on: 02 May 2014, 23:23:08 »
I will have a dig in the garage. I havea couple of seals and I know there is about 2 foot of pipe, one end has the r clip on it and I think it is the passenger side. I should have the other side pipe there too but will need to have a look first.
Al
« Reply #4 on: 03 May 2014, 06:55:06 »
Thanks :y
2woody
  • Northumberland
« Reply #5 on: 03 May 2014, 11:25:46 »
I've got the stuff if he can't find it.....
al brown
  • alton, hants
« Reply #6 on: 03 May 2014, 12:46:12 »
Cheers, I can only find the one side and one of the 3 seals isn't great.
Al
Page created in 0.025 seconds with 20 queries.
