How much to replace 12 metres of guttering....
Started by chrisgixer, 30 April 2014, 22:22:28
Stemo
Quote from: chrisgixer on 30 April 2014, 22:29:50
It's probably less than £50 in materials.
From screwfix just the guttering, downspout, running outlet and two round to squareline adapters is about £80. I take it you are going for squareline, so much nicer.
But, as has been said, probably less than £200 the lot.
Next door had theirs done, front and back, last month. They were finished in a day so if you've been quoted £1200, that's a grand in labour.
They put two ladders up and then hooked a platform on to them. Looked quite secure.
chrisgixer
It's a communal row, so will have to match existing, whatever it is.
Round? ;D
Bigron
IF you are ok climbing ladders (er, I'm not!), it's an easy job and ought to keep you on the friendly side of £200.......
Ron.
Quote from: chrisgixer on 30 April 2014, 22:24:40
1st floor btw. It's an upstairs flat.
Is your downstairs neighbour be willing to pay half?.......or is the guttering solely your responsibility?
Just a thought. :y
Quote from: Mr. Opti on 01 May 2014, 16:58:25
Just a thought. :y
Are you the freeholder of the building? Because that's who is responsible, I'd have thought.  :-\
Terbs
#20
You have seen my place Chris...I had the rear Fascias and gutter removed, then replaced with the thick PVC and new OG guttering, also one side of the gable end up to the apex, with inner woodwork  replaced as it was rotten, and again replaced with thick PVC.
I did not have the soffits replaced. Total price was £650. Took a day.
However I did pay £300 on top of that for scaffolding as I intended to do the job myself, but when I got up there, the corner and end rafter were so rotten, it was out of my skill level to replace. and too awkward to use ladders only.
The front and other side of the gable end, and front guttering I did myself, without scaffolding
as I could use the front end of the garage to stand on.
As an afternote, the maisonettes on this estate are all covenented so that any top work cost is shared by the bottom maisonette
